I am trying to build Yocto (Zeus) for an i.MX8 chip. The bitbake build fails with errors indicating modules cannot be fetched. I have tried both at work and at home in case there are network security settings causing problems at work. It is currently failing on:
ERROR: Fetcher failure for URL: 'git://git.alsa-project.org/tinycompress.git;protocol=git;branch=master'. Unable to fetch URL from any source.
The following cloning attempt fails both at home and at work:
$ git clone git://git.alsa-project.org/tinycompress.git;protocol=git
Cloning into 'tinycompress'...
fatal: repository 'https://git.alsa-project.org/tinycompress.git/' not found
I have changed the following:
$ git config --global url."https://".insteadOf git://
This allowed the "$ repo sync" step to complete but I am not able to build.
Any help is appreciated.
I had multiple problems to figure out. The network connection at my work was causing the fetch commands to fail. I could fetch all of the repositories except tinycompress at home though. I eventually figured out how to add tinycompress to the project by directly cloning the repository and adding the .tar.gz and tar.gz.done files to the downloads folder. I have now gotten the build to complete. I am waiting on a usb-uart cable to test the output of the build.
Please try it again, Since some problem with alsa fetch, could be due to a bad connection since in our environment it works.
