Hi Team
We are using IMX8 Quad max board. We have downloaded "L_VIRT_4.14.98_2.0.0_4.11_0.10_ga_images_MX8QMMEK" image to the board and made SD card partitions as per document. We have downloaded the android OS image "android_p9.0.0_2.3.5-auto_image_8qmek" from NxP website and loaded to SD card.
From U boot if we run the command "xenmmcboot" getting errors.
lsio_gpio1 [200] not owned by curr partition
Error: lsio_gpio1 Power up failed! (error =4)
Please let us know how to resolve these errors.
Also let us know is there any other OS/RTOS can be run on Xen hypervisor which is supported by iMX8QuadMax?
Best Regards
Ranjith Kumar
解決済! 解決策の投稿を見る。
It looks like PMIC is not completely build in the image or it is failing, i bet may try again.
For mx8QM we have the jailhouse and XEN hypervisor. where you can boot linux, windows, android, Winriver OS.
regards
regards
Hi Team
Will Promox hypervisor will be supported by iMX8QM.
Best Regards
Ranjith Kumar
Thanks for the reply.
There was an issue with the switch3 which should be on while downloading.
Now we are able to boot Android OS without errors.
Best Regards
Ranjith Kumar
