Why VDDHIGH_IN power up before VDDARM and VDDSOC for i.MX6QuadPlus compare to i.MX6Quad SABRE AI?
614 次查看
m_c
Senior Contributor I
In the i.MX6Quad SABRE AI, VDDHIGH_IN power up after VDDARM and VDDSOC.
In the i.MX6QuadPlus SABRE AI, VDDHIGH_IN power before VDDARM and VDDSOC.
Why?
502 次查看
igorpadykov
Hi m.c.
VDDHIGH_IN powers regulators as shown on Figure 50-1. Power system overview
i.MX6DQ Reference Manual, powering it first provides more smooth power-up sequence.
So later i.MX6QuadPlus design use this option. Datasheet describes power-up sequence as follows:
"Power-Up Sequence - For power-up sequence, the restrictions are as follows:
• VDD_SNVS_IN supply must be turned ON before any other power supply. It may be connected
(shorted) with VDD_HIGH_IN supply."
502 次查看
art
Since the VDD_HIGH_IN power rail supplies the on-chip LDO_1P1 voltage regulator that, in turns, supplies the 24MHz oscillator circuit, better is to apply VDD_HIGH_IN first (after or together with VDD_SNVS_IN) during the power-up sequence to provide enough time for the 24MHz oscillator for getting up and running stable before POR_B is released.
Artur
503 次查看
igorpadykov
Hi m.c.
