I would like technical information for the TFT3P5581-E MIPI Display recommended here:
Where can I find the supplier / datasheet / etc...?
Thanks.
Hello Johnathan Feuerstein,
There is no technical information on the NXP website but the manufacturer is Truly Semiconductor. I hope this help you find the datasheet and further technical information.
Thank you for the reply! The manufacturer information was helpful, I was able to get in contact with TRULY to discuss.
FYI this display is a custom part, and so they were not able to provide me technical information directly. I was informed that other customers cannot buy these custom parts without 'authorization'.
But they are able to recommend other display options so I should be able to find another solution. Thanks for the help.
John
Perhaps the following thread may be of help. This display can be connected to the MX7 Sabre board directly and the thread follows a bit of the configuration although it does not provide the datasheet.
https://community.nxp.com/thread/443466
I hope this helps!
