When running mxc_v4l2_overlay, can I set the crop method dynamically?
577 次查看
raoudi82
hi. I'm a newbie for imx6.
mxc_v4l2_overlay is good working on the imx6 board.
I want to set x/y position and video size with VIDIOC_S_CROP ioctl dynamically when running mxc_v4l2_overlay.
I wrote code like below.
run mxc_v4l2_overlay
run key event thread function
when if the key event occurs, apply VIDIOC_S_CROP Ioctl
when my code is running, appear warning messages and wrong video images on LCD.
imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_5 = 0x00000002
I knew IPU examples but I just want to set crop parameters without CPU mediation when running.
what can I do for this?
thank you for your help.
516 次查看
igorpadykov
Hi HanSu
I am afraid this is not possible as IPU is quite sensitive to register changes and
not allow "on fly" changes.
