WEC7 hangs at bootloader when reset switch used
958 次查看
seetha
Hi all,
I am working on SDP 1.1 WEC7. Board hangs at times at bootloader level only when reset switch used to reset the board.
The same issue exists sometimes in SDP 1.2 revision as well. However when reset switch used, SD card won't get detected on explorer.
But if I power it on again, everything will be fine. SD card will get detected as well as no hang.
Anything that I need to change in my boot loader or as far as software concerned ??
Any suggestions ?
Seetharam
标签 (2)
标记 (2)
784 次查看
seetha
This issue has been solved.
784 次查看
YixingKong
Senior Contributor IV
Seetharam
We have not got your response yet and will close the diacussion in 3 days. If you still need help, please feel free to
reply with an update to this discussion.
Yixing
785 次查看
seetha
784 次查看
YixingKong
Seetharam
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the
issue, can we close the discussion? If you still need Freescale help, please feel free to contact us.
Yixing
