Video 1080p
Video 1080p
947 次查看
gerardodiiorio
Hi, all
the imx53 board is capable play fullhd video?
I have to choose between imx53 and beagleboardxm....
regards
gerardo di iorio
788 次查看
WangZening
VGA is using TVE module, the max resolution is WSXGA+(1680x1050), 60Hz.
So, you can't output 1080p through VGA port without resizing. You can resize the video and then output it to VGA.
gerardo di iorio said:
hi, thanks for reply,
In this page https://wiki.linaro.org/Boards/MX53QuickStart  i have read what the full hd ouput is
setting  for hdmi output.
Is possible have the full hd on vga port?
In the reference manual i have read what the SATA port is SATAII with 1.5 G/s , but SATAII not is 3.0G/s?
Was is the correct speed of SATA port?
Gerardo Di Iorio
788 次查看
gerardodiiorio
Gerardo Di Iorio
788 次查看
rlorriaux
Yes it does.
You can find some more documentation here: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX535&nodeId=018rH3ZrDR988D&fpsp=1&...
Have a look at the MMDOCS for more documentation about the codecs.
