VGA red and blue swapped on iMX6 dual plus
1,054 次查看
matbus
We have built a board with an iMX6 dual plus where the analog display output has been swapped so that the red component is output to DISP0_DAT0 through DISP0_DAT7 pads. Is there a way to re-configure this in software?
BR/Mattias
1,041 次查看
igorpadykov
Hi matbus
I am afraid there is no simple way to make remapping as it is fixed in driver and
described in 4.12.10.4 IPU Display Interface Signal Mapping
i.MX 6DualPlus/6QuadPlus Applications Processor for Consumer Products Data Sheet
in general bus mapping is described in sect.37.4.7.5.1 Bus Mapping Unit
i.MX 6DualPlus/6QuadPlus Applications Processor Reference Manual
4 回复数
1,030 次查看
matbus
Ok, thank you for the answer. So the hardware should be updated to get blue bits from DISP0_DAT0 through DISP0_DAT7 pads?
(We have a hardware revision in progress and want to make sure we are not doing a hardware change because of a software misconfiguration).
1,020 次查看
matbus
@igorpadykov can you confirm that the correct color order is blue, green, red counting from DISP0_DAT0? Thanks,Mattias
1,017 次查看
igorpadykov
Hi matbus
correct color order is described in sect.4.12.10.4 IPU Display Interface Signal Mapping
1,042 次查看
igorpadykov
Hi matbus
