Dear I.MX community,
Could you please let me know how to get the stat command in busybox of i.MX28 BSP, as I require the stat command inorder to utilize this stat command in application for getting timestamps of the files & folder entries
Kindly do the needful as early as possible
Thanks in advance,
Srinivasan
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
Hello!
1. You can reconfigure busybox and enable stat command in it.
2. You can simple programm, as example:
#include <stdio.h>
#include <sys/stat.h>
#include <errno.h>
#include <string.h>
int main(int argc, char *argv[])
if (argc != 2)
printf("Unknown file!\n");
else {
struct stat info;
const char *file = argv[1];
if (stat(file, &info))
printf("Failed get information abot \"%s\", errno %d (%s)\n",
file, errno, strerror(errno));
else
printf("Information about %s\n"
"inode %u\n"
"owner %u\n"
"group %u\n"
"size %u\n",
file,
info.st_ino,
info.st_uid,
info.st_gid,
info.st_size);
return 0;
As am new to busy box, Could you pls let me know how to reconfigure the busybox with stat command,
But the above code snippet doesn't give timestamps of folders & file entries, where basically I need to check for time stamps of files & folder entries present in my usb stick in my application
I verified the same in my pc for the file & folders, could you pls help me out how this can be achieved in the i.mx28 target
Timestamp for file
user@user-desktop:~/Desktop$ stat 2.txt
File: `2.txt'
Size: 4065 Blocks: 8 IO Block: 4096 regular file
Device: 807h/2055d Inode: 15469810 Links: 1
Access: (0644/-rw-r--r--) Uid: ( 1000/ user) Gid: ( 1000/ user)
Access: 2014-03-20 11:51:10.111574933 +0530
Modify: 2014-03-20 11:51:09.191579414 +0530
Change: 2014-03-20 11:51:09.191579414 +0530
Time stamp for folder
user@user-desktop:~/Desktop$ stat parser_test
File: `parser_test'
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: 807h/2055d Inode: 17448127 Links: 5
Access: (0755/drwxr-xr-x) Uid: ( 1000/ user) Gid: ( 1000/ user)
Access: 2014-03-20 12:08:16.591577008 +0530
Modify: 2014-03-20 12:08:15.581889479 +0530
Change: 2014-03-20 12:08:15.581889479 +0530
Hello!
For reconfigure BusyBox you should change directory to BusyBox source directory and run "make config" config.
For output format time string you can use http://man7.org/linux/man-pages/man3/strftime.3.html and http://man7.org/linux/man-pages/man2/stat.2.html for get information, example:
#include <stdio.h>
#include <errno.h>
#include <string.h>
#include <time.h>
if (argc != 2)
else {
struct stat info;
else {
char at[30] = {0}, mt[30] = , ct[30] = ;
strftime(at, 30, "%F %T %z", localtime(&info.st_atime));
strftime(mt, 30, "%F %T %z", localtime(&info.st_mtime));
strftime(ct, 30, "%F %T %z", localtime(&info.st_ctime));
"inode %u\n"
"owner %u\n"
"group %u\n"
"size %u\n"
"last access %s\n"
"last modification %s\n"
"last change %s\n",
file,
info.st_ino,
info.st_uid,
info.st_gid,
info.st_size,
at,
mt,
ct);
return 0;
And output:
$ ./a.out a.out
Information about a.out
inode 6291480
owner 1000
group 1000
size 8118
last access 2014-03-20 11:16:12 +0400
last modification 2014-03-20 11:16:11 +0400
last change 2014-03-20 11:16:11 +0400
$ ./a.out /etc
Information about /etc
inode 7340033
owner 0
group 0
size 4096
last access 2014-03-20 11:07:01 +0400
last modification 2014-03-20 11:06:55 +0400
last change 2014-03-20 11:06:55 +0400
