UVC HD camera support for i.mx6 Android
2,251 次查看
ispark
Hello All,
Target: i.mx6 solid-run cubox-i
Android: 4.4.2 1.0.0-rc3
Kernel: 3.0.35
I connect UVC HD Camera and record 640*480 resolution successfully.
And I want to increase the resolution to 1280*720.
BTW, attached patch from NXP only affect to below value.
I/FslCameraHAL( 2298): mMaxWidth:960, mMaxHeight:544
please guide me where should I check.
below is log from i.mx6 android board.
V/CameraHolder( 3901): open camera 0
I/AwesomePlayer( 2299): setDataSource_l(URL suppressed)
I/Camera2ClientBase( 2299): Camerehci_fsl_bus_resume begins, Host 1
a 0: Opened
I/FslCameraHAL( 2299): camera_device open: 0
I/FslCameraHAL( 2299): DeviceAdapter: Create uvc device
ehci_fsl_bus_resume ends, Host 1
E/FslCameraHAL( 2299): Error: format 0x47504a4d not supported!
I/FslCameraHAL( 2299): pixel format: 0x56595559
I/FslCameraHAL( 2299): SupportedPictureSizes: 640 x 480
I/FslCameraHAL( 2299): SupportedPictureSizes: 640 x 360
I/FslCameraHAL( 2299): SupportedPictureSizes: 544 x 288
I/FslCameraHAL( 2299): SupportedPictureSizes: 432 x 240
I/FslCameraHAL( 2299): SupportedPictureSizes: 352 x 288
I/FslCameraHAL( 2299): SupportedPictureSizes: 320 x 240
I/FslCameraHAL( 2299): SupportedPictureSizes: 752 x 416
I/FslCameraHAL( 2299): SupportedPictureSizes: 800 x 448
I/FslCameraHAL( 2299): SupportedPictureSizes: 864 x 480
I/FslCameraHAL( 2299): SupportedPictureSizes: 800 x 600
I/FslCameraHAL( 2299): SupportedPictureSizes: 960 x 544
I/FslCameraHAL( 2299): SupportedPictureSizes: 1024 x 576
I/FslCameraHAL( 2299): SupportedPictureSizes: 960 x 720
I/FslCameraHAL( 2299): SupportedPictureSizes: 1184 x 656
I/FslCameraHAL( 2299): SupportedPictureSizes: 1280 x 720
I/FslCameraHAL( 2299): SupportedPreviewSizes: 960 x 544
I/FslCameraHAL( 2299): SupportedPreviewSizes: 640 x 360
I/FslCameraHAL( 2299): SupportedPreviewSizes: 544 x 288
I/FslCameraHAL( 2299): SupportedPreviewSizes: 432 x 240
I/FslCameraHAL( 2299): SupportedPreviewSizes: 352 x 288
I/FslCameraHAL( 2299): SupportedPreviewSizes: 320 x 240
I/FslCameraHAL( 2299): SupportedPreviewSizes: 752 x 416
I/FslCameraHAL( 2299): SupportedPreviewSizes: 800 x 448
I/FslCameraHAL( 2299): SupportedPreviewSizes: 864 x 480
I/FslCameraHAL( 2299): SupportedPreviewSizes: 800 x 600
I/FslCameraHAL( 2299): SupportedPreviewSizes: 640 x 480
I/FslCameraHAL( 2299): FrameDuration is 33331760, 30000000000
I/FslCameraHAL( 2299): mMaxWidth:1280, mMaxHeight:720
E/FslCameraHAL( 2299): cpu num 1
W/Camera2-Parameters( 2299): buildFastInfo: Camera 0: activeArraySize is missing xmin/ymin!
I/Camera2-Parameters( 2299): Camera 0: Disabling ZSL mode
V/CAM_VideoModule( 3901): mDesiredPreviewWidth=640. mDesiredPreviewHeight=480
D/        ( 2671): AccelSensor enable 1 , handle 0 ,mEnabled 13
E/SensorService( 2671): Error activating sensor 0 (Operation not permitted)
V/CAM_VideoModule( 3901): startPreview
D/        ( 2671): AccelSensor enable 1 , handle 0 ,mEnabled 14
E/BufferQueue( 2296): [com.android.camera2/com.android.camera.VideoCamera] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
V/CAM_VideoModule( 3901): Video snapshot size is 960x720
I/FslCameraHAL( 2299): DEBUG(CreateDefaultRequest): making template (1)
I/FslCameraHAL( 2299): DEBUG(CreateDefaultRequest): making template (3)
I/FslCameraHAL( 2299): RequestManager allocateStream...
I/FslCameraHAL( 2299): allocateStream preview stream, w:640, h:480, fmt:0x22
I/FslCameraHAL( 2299): actual format 0x103
I/FslCameraHAL( 2299): RequestManager allocateStream end...
I/FslCameraHAL( 2299): RequestManager registerStreamBuffers stream id:0
I/FslCameraHAL( 2299): registerBuffers total 5 buffer
I/FslCameraHAL( 2299): RequestManager registerStreamBuffers end...
I/FslCameraHAL( 2299): allocateStream jpeg stream, w:960, h:720, fmt:0x21
I/FslCameraHAL( 2299): RequestManager registerStreamBuffers stream id:3
I/FslCameraHAL( 2299): notify_request_queue_not_empty running
I/FslCameraHAL( 2299): dispatchRequest running
I/FslCameraHAL( 2299): handleRequest running
I/FslCameraHAL( 2299): PreviewStream configure running
I/FslCameraHAL( 2299): is Width * Height 640 x 480 format 0x56595559, fps: 30
I/ActivityManager( 2671): Displayed com.android.camera2/com.android.camera.VideoCamera: +696ms
I/FslCameraHAL( 2299): PreviewStream start running
I/FslCameraHAL( 2299): StreamAdapter start running
I/FslCameraHAL( 2299): stream thread received STREAM_START command
I/FslCameraHAL( 2299): Created device thread
826 次查看
weidong_sun
Hi Park,
     The log you sent is no problem, 720P has been supported, you know ? 640x480 resolution of preview is just defualt, if you don't want some resolutions, you can filter out them in HAL, see "CameraFrame * UvcDevice::acquireCameraFrame()" in UvcDevice.cpp file.
     You had better take some time to read code of the file.
Weidong
826 次查看
ispark
Yes, you're right it support below resolution.
I/FslCameraHAL( 2293): SupportedPictureSizes: 640 x 480
I/FslCameraHAL( 2293): SupportedPictureSizes: 2592 x 1944
I/FslCameraHAL( 2293): SupportedPreviewSizes: 800 x 600
I/FslCameraHAL( 2293): SupportedPreviewSizes: 320 x 240
I/FslCameraHAL( 2293): SupportedPreviewSizes: 640 x 480
for configure default resolution I modified below file.
./out/target/product/cuboxi/obj/ETC/media_profiles.xml_intermediates/media_profiles.xml
               width="800"
               height="600"
               frameRate="30" />
then it affect to below.
./out/target/product/cuboxi/system/etc/media_profiles.xml
but maybe another source would affect to above file.
any info for original media_profiles.xml would be appreciated.
826 次查看
ispark
Hi Weidong,
Thanks for your response, I studying UvcDevice.cpp hardly but slow to understand.
Also tries to filter out other resolution.
My purpose is set video recording resolution to 1280 x 720.
Android camera apk does not show this configuration.
Please let me know where should I set/modify for this.
