UART3 on i.MX 8M Mini
2,984 次查看
josc
I try to use UART3 on i.MX 8M Mini LPDDR4 EVKB M4 core but I'm not getting any signals. I'm using the evkmimx8mm_iuart_interrupt_transfer example. I edited pin_mux.c:
IOMUXC_SetPinMux(IOMUXC_UART3_RXD_UART3_RX, 0U);
IOMUXC_SetPinConfig(IOMUXC_UART3_RXD_UART3_RX,
IOMUXC_SW_PAD_CTL_PAD_DSE(6U) | IOMUXC_SW_PAD_CTL_PAD_FSEL(2U));
IOMUXC_SetPinMux(IOMUXC_UART3_TXD_UART3_TX, 0U); IOMUXC_SetPinConfig(IOMUXC_UART3_TXD_UART3_TX,
I also had to edit the function BOARD_BootClockRUN() in clock_config.c:
CLOCK_SetRootMux(kCLOCK_RootUart3, kCLOCK_UartRootmuxSysPll1Div10);
CLOCK_SetRootDivider(kCLOCK_RootUart3, 1U, 1U);
CLOCK_EnableClock(kCLOCK_Uart3);
And I of course changed the definitions in main.c:
#define DEMO_UART UART3
#define DEMO_UART_CLK_FREQ \
CLOCK_GetPllFreq(kCLOCK_SystemPll1Ctrl) / (CLOCK_GetRootPreDivider(kCLOCK_RootUart3)) / \ (CLOCK_GetRootPostDivider(kCLOCK_RootUart3)) / 10
The Boot Switches are in Download Mode and I'm uploading the code via J-Link. I also configured UART3 in RDC. Therefore should UART3 be accessible with the M4, right?
I connected Pin 8, which should be UART3 TX, from the Expansion Connector J1003 on an oscilloscope to detect signals but I can't see anything. What am I missing here?
2,860 次查看
josc
I could fix the issue by using the correct PinMux configuration. Instead of IOMUXC_UART3_RXD_UART3_RX  and IOMUXC_UART3_TXD_UART3_TX I'm using IOMUXC_ECSPI1_SCLK_UART3_RX and IOMUXC_ECSPI1_MOSI_UART3_TX now.
Thank you for your help!
5 回复数
2,950 次查看
josc
There's no dts when the switches are in Download mode. So UART3 should be free to use.
2,871 次查看
joanxie
do you dts has this? if yes, you need set to "disabled," pls double check it
linux-imx/arch/arm64/boot/dts/freescale/imx8mm-evk.dtsi at lf-6.6.y · nxp-imx/linux-imx · GitHub
&uart3 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart3>;
assigned-clocks = <&clk IMX8MM_CLK_UART3>;
assigned-clock-parents = <&clk IMX8MM_SYS_PLL1_80M>;
fsl,uart-has-rtscts;
status = "okay";
2,861 次查看
josc
2,612 次查看
Vishal-K-V
This worked for me as well , But I want to ask why we have done this.
2,969 次查看
joanxie
could you confirm if your dts doesn't use uart3? if linux side uses this, you need disable this firstly, I don't know how your SW is, you can check it by yourself
%3CLINGO-SUB%20id%3D%22lingo-sub-1931780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUART3%20on%20i.MX%208M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1931780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20i.MX%208M%20Mini%20LPDDR4%20EVKB%20M4%20%E6%A0%B8%E5%BF%83%E4%B8%8A%E4%BD%BF%E7%94%A8%20UART3%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E4%BB%BB%E4%BD%95%E4%BF%A1%E5%8F%B7%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20evkmimx8mm_iuart_interrupt_transfer%20%E7%A4%BA%E4%BE%8B%E3%80%82%E6%88%91%E7%BC%96%E8%BE%91%E4%BA%86pin_mux.c%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3EIOMUXC_SetPinMux(IOMUXC_UART3_RXD_UART3_RX%2C%200U)%3B%20%0AIOMUXC_SetPinConfig(IOMUXC_UART3_RXD_UART3_RX%2C%20%0AIOMUXC_SW_PAD_CTL_PAD_DSE(6U)%20%7C%20IOMUXC_SW_PAD_CTL_PAD_FSEL(2U))%3B%20%0AIOMUXC_SetPinMux(IOMUXC_UART3_TXD_UART3_TX%2C%200U)%3B%20IOMUXC_SetPinConfig(IOMUXC_UART3_TXD_UART3_TX%2C%20%0AIOMUXC_SW_PAD_CTL_PAD_DSE(6U)%20%7C%20IOMUXC_SW_PAD_CTL_PAD_FSEL(2U))%3B%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%BF%98%E5%BF%85%E9%A1%BB%E7%BC%96%E8%BE%91clock_config.c%E4%B8%AD%E7%9A%84%E5%87%BD%E6%95%B0BOARD_BootClockRUN()%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3ECLOCK_SetRootMux(kCLOCK_RootUart3%2C%20kCLOCK_UartRootmuxSysPll1Div10)%3B%0ACLOCK_SetRootDivider(kCLOCK_RootUart3%2C%201U%2C%201U)%3B%0ACLOCK_EnableClock(kCLOCK_Uart3)%3B%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E7%84%B6%EF%BC%8C%E6%88%91%E4%B9%9F%E6%94%B9%E5%8F%98%E4%BA%86%20main.c%20%E4%B8%AD%E7%9A%84%E5%AE%9A%E4%B9%89%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%23define%20DEMO_UART%20UART3%20%0A%23define%20DEMO_UART_CLK_FREQ%20%5C%20%0ACLOCK_GetPllFreq(kCLOCK_SystemPll1Ctrl)%20%2F%20(CLOCK_GetRootPreDivider(kCLOCK_RootUart3))%20%2F%20%5C%20(CLOCK_GetRootPostDivider(kCLOCK_RootUart3))%20%2F%2010%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%90%AF%E5%8A%A8%E5%BC%80%E5%85%B3%E5%A4%84%E4%BA%8E%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E9%80%9A%E8%BF%87%20J-Link%20%E4%B8%8A%E4%BC%A0%E4%BB%A3%E7%A0%81%E3%80%82%E6%88%91%E8%BF%98%E5%9C%A8%20RDC%20%E4%B8%AD%E9%85%8D%E7%BD%AE%E4%BA%86%20UART3%E3%80%82%E5%9B%A0%E6%AD%A4%20UART3%20%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20M4%20%E8%AE%BF%E9%97%AE%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E6%89%A9%E5%B1%95%E8%BF%9E%E6%8E%A5%E5%99%A8%20J1003%20%E7%9A%84%E5%BC%95%E8%84%9A%208%EF%BC%88%E5%BA%94%E8%AF%A5%E6%98%AF%20UART3%20TX%EF%BC%89%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%A4%BA%E6%B3%A2%E5%99%A8%E4%B8%8A%E4%BB%A5%E6%A3%80%E6%B5%8B%E4%BF%A1%E5%8F%B7%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%80%E4%B9%88%E4%B9%9F%E7%9C%8B%E4%B8%8D%E5%88%B0%E3%80%82%E6%88%91%E5%9C%A8%E8%BF%99%E9%87%8C%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1931780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1977786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20on%20i.MX%208M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E5%AF%B9%E6%88%91%E4%B9%9F%E6%9C%89%E7%94%A8%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E9%97%AE%E6%88%91%E4%BB%AC%E4%B8%BA%E4%BB%80%E4%B9%88%E8%BF%99%E6%A0%B7%E5%81%9A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1937072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20on%20i.MX%208M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1937072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%20PinMux%20%E9%85%8D%E7%BD%AE%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%20IOMUXC_ECSPI1_SCLK_UART3_RX%20%E5%92%8C%20IOMUXC_ECSPI1_MOSI_UART3_TX%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20IOMUXC_UART3_RXD_UART3_RX%20%E5%92%8C%20IOMUXC_UART3_TXD_UART3_TX%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1936871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20on%20i.MX%208M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1936871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E7%9A%84DTS%E6%9C%89%E8%BF%99%E4%B8%AA%E5%8A%9F%E8%83%BD%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%9C%89%EF%BC%8C%E4%BD%A0%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AE%E4%B8%BA%E2%80%9C%E7%A6%81%E7%94%A8%E2%80%9D%EF%BC%8C%E8%AF%B7%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.6.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm-evk.dtsi%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elinux-imx%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm-evk.dtsi%20%E5%9C%A8%20lf-6.6.y%C2%B7%20nxp-imx%2Flinux-imx%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%26amp%3Buart3%20%7B%3CBR%20%2F%3E%20pinctrl%20%E5%90%8D%E7%A7%B0%20%3D%20%E2%80%9C%E9%BB%98%E8%AE%A4%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart3%26gt%3B%3B%3CBR%20%2F%3E%E5%88%86%E9%85%8D%E6%97%B6%E9%92%9F%3D%26lt%3B%26amp%3Bclk%20IMX8MM_CLK_UART3%26gt%3B%EF%BC%9B%3CBR%20%2F%3E%E5%88%86%E9%85%8D%E7%9A%84%E6%97%B6%E9%92%9F%E7%88%B6%E7%BA%A7%3D%26lt%3B%26amp%3Bclk%20IMX8MM_SYS_PLL1_80M%26gt%3B%EF%BC%9B%3CBR%20%2F%3E%20fsl%EF%BC%8Cuart%E6%9C%89rtscts%EF%BC%9B%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1932011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20on%20i.MX%208M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1932011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E4%BA%A4%E6%8D%A2%E6%9C%BA%E5%A4%84%E4%BA%8E%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%E6%97%B6%EF%BC%8C%E6%B2%A1%E6%9C%89%20dts%E3%80%82%E5%9B%A0%E6%AD%A4%20UART3%20%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E8%87%AA%E7%94%B1%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1931862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UART3%20on%20i.MX%208M%20Mini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1931862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%BD%A0%E7%9A%84dts%E6%98%AF%E5%90%A6%E4%B8%8D%E4%BD%BF%E7%94%A8uart3%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9CLinux%E7%AB%AF%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%EF%BC%8C%E4%BD%A0%E9%9C%80%E8%A6%81%E5%85%88%E7%A6%81%E7%94%A8%E5%AE%83%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%BD%A0%E7%9A%84SW%E6%98%AF%E6%80%8E%E4%B9%88%E6%A0%B7%E7%9A%84%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%87%AA%E5%B7%B1%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E
