TZC380 on iMX6Q/7D: AXI ID and AID_WIDTH
1,063件の閲覧回数
vsiles
Senior Contributor I
Hi everyone,
I am trying to configure a TZASC (TZC380) in my secure kernel to prevent Linux and some DMA to mess with the secure part of DRAM. In the documentation, the FAIL ID register holds the identifier of the faulty master. The id n = AID_WIDTH-1 bit long, and represent the master AXI ID.
Where can I find the value of AID_WIDTH and a table listing the possible master AXI ID ?
Vincent
ラベル(3)
タグ(2)
696件の閲覧回数
Yuri
   AXI ID may be found in the i.MX6 D/Q, S/DL RMs in sections “MMDC Profiling”.
No more information, sorry.
Yuri
4 返答(返信)
697件の閲覧回数
Yuri
Yuri
696件の閲覧回数
vsiles
Thank you for this information ! I am not sure I understand exactly what the 'x' are for in this table. For example for ARM_S0, we can read 14'b000xxxxxxxx000. Does it mean that the full AXI ID of ARM_S0 is this pattern with 'x's replaced by the master id of ARM_S0 ?
Thank you for your help,
Vincent
696件の閲覧回数
Yuri
Basically - yes. The 'x' fields may be changed, say, by internal switch fabric.
Yuri.
696件の閲覧回数
vsiles
Fair enough. Thank you for your helpful support !
I'll wait a bit if anyone can help on the AID_WIDTH part before marking the question as 'answered'.
Vincent
