Starting GStreamer with systemd.
已解决
跳至解决方案
2,643 次查看
Patrick-Kim
There is an issue starting GStreamer with systemd.
Entering the following command produces an error message and the video doesn't appear.
Help me find a solution.
root@imx8mpevk:~# systemctl start myservice
root@imx8mpevk:~# systemctl status myservice
* myservice.service - test service
Loaded: loaded (/etc/systemd/system/myservice.service; disabled; preset: disabled)
Active: active (running) since Tue 2024-05-14 02:12:25 UTC; 7s ago
Main PID: 834 (myservice.sh)
Tasks: 2 (limit: 5574)
Memory: 5.1M
CGroup: /system.slice/myservice.service
|-834 /bin/bash /home/root/myservice.sh
`-841 sleep 10
May 14 02:12:25 imx8mpevk systemd[1]: Started test service.
May 14 02:12:25 imx8mpevk myservice.sh[834]: gst start!!
May 14 02:12:25 imx8mpevk myservice.sh[835]: Setting pipeline to PAUSED ...
May 14 02:12:25 imx8mpevk myservice.sh[835]: Failed to set pipeline to PAUSED.
May 14 02:12:25 imx8mpevk myservice.sh[835]: Setting pipeline to NULL ...
May 14 02:12:25 imx8mpevk myservice.sh[835]: Freeing pipeline ...
The same shell script works fine when executed in the console, I can see the video.
root@imx8mpevk:~# ./myservice.sh
gst start!!
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
[ 1033.191967] bypass csc
[ 1033.194381] input fmt YUV4
[ 1033.197096] output fmt YUYV
Redistribute latency...
0:00:00.8 / 99:99:99.
Here is my "myservice.service" and "myservice.sh" file.
myservice.service
[Unit]
Description=GStreamer
After=multi-user.target
[Service]
Type=simple
User=root
ExecStart=/home/root/myservice.sh
RemainAfterExit=yes
GuessMainPID=no
myservice.sh
#!/bin/bash
export XDG_RUNTIME_DIR=/run/user/0/
echo gst start!!
gst-launch-1.0 v4l2src device=/dev/video2 ! waylandsink
Please help!!
1 解答
2,583 次查看
Patrick-Kim
Although no one was interested, I found a solution on my own and have summarized it here.
myprogram.service
[Unit]
Description=My Last Service
After=weston.service
[Service]
User=root
Environment="WAYLAND_DISPLAY=/run/wayland-0"
Environment="XDG_RUNTIME_DIR=/run/user/$(id -u root)"
ExecStart=/home/root/run.sh
Restart=on-failure
StandardOutput=journal
StandardError=journal
[Install]
WantedBy=multi-user.target
run.sh
echo Start GST!!
Register service
systemctl daemon-reload
systemctl enable myprogram.service
This way, it works well for me. When I reboot, the camera screen comes up automatically.
在原帖中查看解决方案
1 回复
2,584 次查看
Patrick-Kim
myprogram.service
[Unit]
[Service]
User=root
Restart=on-failure
[Install]
run.sh
echo Start GST!!
Register service
%3CLINGO-SUB%20id%3D%22lingo-sub-1864953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20systemd%20%E5%90%AF%E5%8A%A8%20GStreamer%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1864953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%BF%E7%94%A8%20systemd%20%E5%90%AF%E5%8A%A8%20GStreamer%20%E6%97%B6%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E4%BC%9A%E4%BA%A7%E7%94%9F%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%A7%86%E9%A2%91%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3E%E5%B8%AE%E6%88%91%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CFONT%20size%3D%222%22%3Eroot%40imx8mpevk%3A~%23%20systemctl%20%E5%90%AF%E5%8A%A8%20myservice%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20size%3D%222%22%3Eroot%40imx8mpevk%3A~%23%20systemctl%20status%20myservice%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20size%3D%222%22%3E*%20myservice.service%20-%20%E6%B5%8B%E8%AF%95%E6%9C%8D%E5%8A%A1%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E5%B7%B2%E5%8A%A0%E8%BD%BD%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%EF%BC%88%2Fetc%2Fsystemd%2Fsystem%2Fmyservice.service%EF%BC%9B%E5%B7%B2%E7%A6%81%E7%94%A8%EF%BC%9B%E9%A2%84%E8%AE%BE%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E6%B4%BB%E8%B7%83%EF%BC%9A%E8%87%AA%202024%20%E5%B9%B4%205%20%E6%9C%88%2014%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C%2002%3A12%3A25%20UTC%20%E4%BB%A5%E6%9D%A5%207%20%E7%A7%92%E5%89%8D%E5%A4%84%E4%BA%8E%E6%B4%BB%E8%B7%83%E7%8A%B6%E6%80%81%EF%BC%88%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E4%B8%BB%20PID%EF%BC%9A834%EF%BC%88myservice.sh%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E4%BB%BB%E5%8A%A1%EF%BC%9A2%EF%BC%88%E9%99%90%E5%88%B6%EF%BC%9A5574%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E5%86%85%E5%AD%98%EF%BC%9A5.1M%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20size%3D%222%22%3ECGroup%EF%BC%9A%2Fsystem.slice%2Fmyservice.service%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C-834%20%2Fbin%2Fbash%20%2Fhome%2Froot%2Fmyservice.sh%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20size%3D%222%22%3E%60-841%20%E7%9D%A1%E7%9C%A0%2010%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A5%2002%3A12%3A25%20imx8mpevk%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%B5%8B%E8%AF%95%E6%9C%8D%E5%8A%A1%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A5%2002%3A12%3A25%20imx8mpevk%20myservice.sh%5B834%5D%3A%20gst%20%E5%90%AF%E5%8A%A8%EF%BC%81%EF%BC%81%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A5%2002%3A12%3A25%20imx8mpevk%20myservice.sh%5B835%5D%3A%20%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81...%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A5%2002%3A12%3A25%20imx8mpevk%20myservice.sh%5B835%5D%3A%20%E6%97%A0%E6%B3%95%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A5%2002%3A12%3A25%20imx8mpevk%20myservice.sh%5B835%5D%3A%20%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%20NULL%20...%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A5%2002%3A12%3A25%20imx8mpevk%20myservice.sh%5B835%5D%3A%20%E9%87%8A%E6%94%BE%E7%AE%A1%E9%81%93...%3C%2FFONT%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E7%9B%B8%E5%90%8C%E7%9A%84%20shell%20%E8%84%9A%E6%9C%AC%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E6%89%A7%E8%A1%8C%E6%97%B6%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E8%A7%86%E9%A2%91%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3Eroot%40imx8mpevk%3A~%23%20.%2Fmyservice.sh%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E6%B6%88%E8%B4%B9%E7%A8%8E%E5%BC%80%E5%A7%8B%EF%BC%81%EF%BC%81%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E7%AE%A1%E9%81%93%E6%98%AF%E6%B4%BB%E7%9A%84%EF%BC%8C%E4%B8%8D%E9%9C%80%E8%A6%81%E9%A2%84%E6%BB%9A......%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E7%AE%A1%E9%81%93%E9%87%87%E7%94%A8%E9%A2%84%E5%8D%B7...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%92%AD%E6%94%BE...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E6%96%B0%E6%97%B6%E9%92%9F%EF%BC%9AGstSystemClock%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B1033.191967%5D%20%E7%BB%95%E8%BF%87%20CSC%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B1033.194381%5D%20%E8%BE%93%E5%85%A5%E6%A0%BC%E5%BC%8F%20YUV4%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B1033.197096%5D%20%E8%BE%93%E5%87%BA%E6%A0%BC%E5%BC%8F%20YUYV%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E9%87%8D%E6%96%B0%E5%88%86%E9%85%8D%E5%BB%B6%E8%BF%9F...%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E0%3A00%3A00.8%20%2F%2099%3A99%3A99.%3C%2FFONT%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E2%80%9Cmyservice.service%E2%80%9D%E5%92%8C%E2%80%9Cmyservice.sh%E2%80%9D%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3Emyservice.service%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BUnit%5D%0ADescription%3DGStreamer%0AAfter%3Dmulti-user.target%0A%0A%5BService%5D%0AType%3Dsimple%0AUser%3Droot%0AExecStart%3D%2Fhome%2Froot%2Fmyservice.sh%0ARemainAfterExit%3Dyes%0AGuessMainPID%3Dno%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3Emyservice.sh%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23!%2Fbin%2Fbash%0A%0Aexport%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F0%2F%0Aecho%20gst%20start!!%0Agst-launch-1.0%20v4l2src%20device%3D%2Fdev%2Fvideo2%20!%20waylandsink%0A%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%BF%99%EF%BC%81%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20systemd%20%E5%90%AF%E5%8A%A8%20GStreamer%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E6%B2%A1%E6%9C%89%E4%BA%BA%E6%84%9F%E5%85%B4%E8%B6%A3%EF%BC%8C%E4%BD%86%E6%88%91%E8%87%AA%E5%B7%B1%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%AD%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%80%BB%E7%BB%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E7%A8%8B%E5%BA%8F.%E6%9C%8D%E5%8A%A1%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%5B%E5%8D%95%E5%85%83%5D%3CBR%20%2F%3E%E6%8F%8F%E8%BF%B0%3D%E6%88%91%E7%9A%84%E4%B8%8A%E6%AC%A1%E6%9C%8D%E5%8A%A1%3CBR%20%2F%3E%E4%B9%8B%E5%90%8E%3Dweston.service%3C%2FP%3E%3CP%3E%5B%E6%9C%8D%E5%8A%A1%5D%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%3Droot%3CBR%20%2F%3E%E7%8E%AF%E5%A2%83%3D%E2%80%9CWAYLAND_DISPLAY%20%3D%20%2F%E8%BF%90%E8%A1%8C%2F%20wayland-0%E2%80%9D%3CBR%20%2F%3E%E7%8E%AF%E5%A2%83%3D%E2%80%9CXDG_RUNTIME_DIR%20%3D%20%2F%E8%BF%90%E8%A1%8C%2F%E7%94%A8%E6%88%B7%2F%20%24%EF%BC%88id%20-u%20root%EF%BC%89%E2%80%9D%3CBR%20%2F%3E%20ExecStart%3D%2Fhome%2Froot%2Frun.sh%3CBR%20%2F%3E%E5%A4%B1%E8%B4%A5%E6%97%B6%E9%87%8D%E5%90%AF%3CBR%20%2F%3E%E6%A0%87%E5%87%86%E8%BE%93%E5%87%BA%3D%E6%97%A5%E5%BF%97%3CBR%20%2F%3E%E6%A0%87%E5%87%86%E9%94%99%E8%AF%AF%3D%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3E%5B%E5%AE%89%E8%A3%85%5D%3CBR%20%2F%3E%20WantedBy%3D%E5%A4%9A%E7%94%A8%E6%88%B7.%E7%9B%AE%E6%A0%87%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%BF%90%E8%A1%8C%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Eecho%20%E5%BC%80%E5%A7%8B%20GST%EF%BC%81%EF%BC%81%3C%2FP%3E%3CP%3Egst-%E5%90%AF%E5%8A%A8-1.0v4l2src%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo2%EF%BC%81%E9%9F%A6%E5%85%B0%E8%BE%9B%E5%85%8B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%B3%A8%E5%86%8C%E6%9C%8D%E5%8A%A1%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Esystemctl%20%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E9%87%8D%E6%96%B0%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Esystemctl%20%E5%90%AF%E7%94%A8%20myprogram.service%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%BF%99%E6%A0%B7%EF%BC%8C%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E6%95%88%E6%9E%9C%E5%BE%88%E5%A5%BD%E3%80%82%E5%BD%93%E6%88%91%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E7%9B%B8%E6%9C%BA%E5%B1%8F%E5%B9%95%E8%87%AA%E5%8A%A8%E5%87%BA%E7%8E%B0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
