Signing firmware part by part
960 次查看
prashanweerasin
Hi All,
I am currently working on performing secure boot on imx6ul using habv4. In my system the firmware is separated in to two parts other than boot loader. One is with kernel+rootfs (Part A) and the other part contains some critical application services (Part B) provided by another party (it’s mounted as a separate partition to the OS). The idea is to bug fix or change one part and flash it to the system without touching or bothering about the other.
I followed the steps provided by nxp and successfully signed and verified the boot loader and the complete firmware part (Part A + Part B) without any HAB events.
But when signing kernel + rootfs + critical app part (Part A + Part B), since the all signatures information are given in a single csf file which is embedded in the final image, I will not be able to write the Part A (kernel+rootfs) or Part B (critical app part ) separately after changing one part. How can I sign two parts separately so I can update only the relevant part and respective signature?
Thank you,
Pra
标记 (2)
853 次查看
Yuri
U-boot can authenticate other additional parts of system, using
authenticate_image function for it in the same manner as for  uImage.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
854 次查看
Yuri
Yuri
button. Thank you!
853 次查看
prashanweerasin
Hi Yuri,
Thank you very much for replying me.
If I understood correctly you are suggesting to invoke authenticate_image function using u-boot script. Is there any other way to automate this ?
Pra.
853 次查看
Yuri
Hi, Pra !
  I am afraid we do not have examples (automation technique) for
using several signing parts with U-boot.
You should call  additional authenticate_image function from U-boot.
Yuri.
