SPI-NOR programming with MFGTOOL
905 次查看
jparrish88
What is required to program SPI-NOR from the MFGTOOL on a custom board?
In other words what steps are necessary?
标记 (1)
565 次查看
igorpadykov
Hi jparrish88
please look at Linux Doc bundle
L3.0.35_4.1.0_LINUX_DOCS
i.MX_6Dual6Quad_BSP_Porting_Guide.pdf
Chapter 5 "Configuring the SPI NOR Flash Memory Technology Device (MTD) Driver",
then one needs to rebuild MFG Tool image (firmware file initramfs.cpio.gz.uboot)
check i.MX_6Dual6Quad_SABRE-SD_Linux_User's_Guide.pdf
sect.3.9 "Building Manufacturing Firmware".
chip
566 次查看
igorpadykov
Hi jparrish88
chip
