SGTL5000 datasheet formula error
918件の閲覧回数
erikfriesen
Page 56 of the sgtl5000 datasheet has two formulas for calculating the attack and release rate.  They both don't work for me.
Excel calcs are
#1 = (1-(10^(-(A9/(20*B9))))*2^19) and the result for (A9 or rate_dBs = 32) and (B9 or SYS_FS = 44.1) = -482267 or FFFFF8a425
#1 = (1-(10^(-(A9/(20*B9))))*2^19) and the result for (A9 or rate_dBs = 32) and (B9 or SYS_FS = 1) = -13168 or FFFFFFCC90
Raw formula says (1 - (10^(-(Rate_dBs/(20*SYS_FS)))) * 2^19
Anyway, this formula shouldn't be this complex.  Just give the clock calculations and the math should be straitforward.
タグ(1)
3 返答(返信)
700件の閲覧回数
art
I have checked the formula, it is correct. The point is that the SYS_FS value in the formula should be specified in the units of Hz, not kHz. So, for example, for the sampling rate of 48kHz (48000Hz) and attack rate of 32dB/s the calculation is:
(1-(10^(-(32/(20*48000)))))*524288 = approx. 40.239 = approx. 40 = 0x28
that corresponds to the example value, given in the Data Sheet document.
Artur
700件の閲覧回数
erikfriesen
Well, I suppose I should have tried adding the ')' where you did, but look at the datasheet again, the closing ')' is missing
700件の閲覧回数
erikfriesen
Just throwing out some guesses
Its an overflow ticker, so
#1 = 0x10000 / Clock * dBsecond
#2 = 0x100000 / Clock * dBsecond
These come out in the ballpark anyway.
