SAF775x(Dirana 3)- How the data is being routed from Mic to SOC (Rx Side) AND Soc to speaker(Tx Side)
3,403件の閲覧回数
tobin_tomy
In Dirana 3, we have 2 EPIC cores and 1 Hifi core is there for Audio Processing. As per my initial level of understanding, EPIC cores will take care about the audio routing by some framework API's. I would like to know how the Audio Samples will be processed from Mic---ADC--Receiver--DSP---Transmitter--DAC---Speakers?  Since I am new to Dirana 3, It would be helpful if you are able to suggest some supportive document for the same. Thanks in Advance.
0 返答(返信)
