Hello community,
I'm thinking of using a mipi camera with the i.Mx8.
So, as i.Mx8, I would like to know how much voltage the differential inputs require as data and clock signals.
Solved! Go to Solution.
I didn't know how to use community.
After confirming this message, the problem has been solved, so I will " accept as solution".
Thank you very much.
Hi @biginner_man,
I hope you are doing well.
i.MX8MP's MIPI CSI host controller is compliant with MIPI D-PHY specification V1.2. One can refer to the MIPI D-PHY specification V1.2 for voltage specifications.
Thanks & Regards,
Ritesh M Patel
Thank you for contacting.
When I checked it, there was a description of 700mV differential input.(data rate<=1.5G)
Thank you for guiding me to the solution.
