At present I am working on sabre platform for autoinfotainment.
and we could hear the same.
However
But No audio is getting played out, instead audio is still getting played on J26 only.
Would like to know, Does BSP has support to play Second audio as mentioned above?
Please let me know
Srilakshmi
已解决! 转到解答。
I was investigating and doing some trial and error experiments and I was able to find some configuration suitable for hearing audio in J27-1.
You only need to create a file asound.conf in /etc/ directory
# vim /etc/asound.conf
And copy paste the next as content
pcm.dsplit {
type dmix
ipc_key 2048
slave {
pcm "hw:0,0"
channels 4
bindings {
0 0
2 1
1 2
3 3
pcm.j26_3 {
type plug
slave {
pcm "dsplit"
channels 4
ttable.0.0 1
ttable.1.1 1
pcm.j27_1 {
type plug
slave {
pcm "dsplit"
channels 4
ttable.0.2 1
ttable.1.3 1
Next play through J26-3 by
# aplay -D j26_3 stereo.wav
or by J27=1 by
# aplay -D j27_1 stereo.wav
You can find some useful info about the asound.conf and .asoundrc here http://alsa.opensrc.org/.asoundrc
Hi Srilakshmi
plughw:0,0 (7.1 audio-codec) supports up to 8 channels and they are mapped as follows
ch1 and ch2: J26-3
ch3 and ch4: J27-1
ch5 and ch6: J27-2
ch7 and ch8: J27-3
While plughw:0,1 (ASRC audio codec) only supports 2 to 6 channles. They are mapped as follows:
ch1 and ch2: J26-3
ch3 and ch4: J27-1
ch5 and ch6: J27-2
So by executing aplay -Dplughw:0,1 <file.wav> you are just picking the ASRC codec driver not channel mapping .
For hearing sound in the J27 you need to use a 4, 6, or 8 channel wave file.
You can download the 6_Channel_ID.wav and 8_Channel_ID.wav files from Wave File Examples
Try
aplay -Dplughw:0,0 8_Channel_ID.wav ---> you will hear sound through J26-3, J27-1, J27-2 and J27-3
aplay -Dplughw:0,1 8_Channel_ID.wav ---> you will get an error since ASRC only supports up to 6 channels
aplay -Dplughw:0,0 6_Channel_ID.wav ---> you will hear sound through J26-3, J27-1 and J27-2
aplay -Dplughw:0,1 6_Channel_ID.wav ---> you will hear sound through J26-3, J27-1 and J27-2
I don't know if is possible to change the channel mapping. I guess this implies some modifications in the driver code.
pcm.dsplit {
type dmix
ipc_key 2048
slave {
pcm "hw:0,0"
channels 4
bindings {
0 0
2 1
1 2
3 3
pcm.j26_3 {
type plug
slave {
pcm "dsplit"
channels 4
ttable.0.0 1
ttable.1.1 1
pcm.j27_1 {
type plug
slave {
pcm "dsplit"
channels 4
ttable.0.2 1
ttable.1.3 1
or by J27=1 by
