Reboot not working Imx8mq
已解决
跳至解决方案
3,523 次查看
saurav-pandya
I am working on custom imx8mq board. Reboot functionality is not working.
Dmesg log :
root@imx8mqwave:~# dmesg | grep -i watch
[ 0.060842] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.596813] imx2-wdt 30280000.watchdog: timeout 60 sec (nowayout=0)
After reboot command log :
[ OK ] Reached target Reboot.
[ 37.249047] watchdog: watchdog0: watchdog did not stop!
[ 37.257902] printk: systemd-shutdow: 32 output lines suppressed due to ratelimiting
[ 37.276780] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 37.283557] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 37.296947] systemd-journald[232]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 37.309843] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 37.324276] systemd-shutdown[1]: Hardware watchdog 'imx2+ watchdog', version 0
[ 37.332798] systemd-shutdown[1]: Unmounting file systems.
[ 37.339762] [351]: Remounting '/' read-only in with options '(null)'.
[ 37.358767] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 37.368704] systemd-shutdown[1]: All filesystems unmounted.
[ 37.374293] systemd-shutdown[1]: Deactivating swaps.
[ 37.379397] systemd-shutdown[1]: All swaps deactivated.
[ 37.384639] systemd-shutdown[1]: Detaching loop devices.
[ 37.392321] systemd-shutdown[1]: All loop devices detached.
[ 37.403337] imx-sdma 30bd0000.dma-controller: external firmware not found, using ROM firmware
[ 37.403420] kvm: exiting hardware virtualization
[ 37.418815] imx-sdma 302c0000.dma-controller: loaded firmware 4.5
[ 37.460048] imx2-wdt 30280000.watchdog: Device shutdown: Expect reboot!
[ 37.467160] reboot: Restarting system
Please help me on same what is issue.
Saurav
1 解答
3,393 次查看
Junjielu
Hi Saurav,
Have you got the answer yet?  I got the same problem on my custom board!!
thanks,
Jason
在原帖中查看解决方案
5 回复数
3,273 次查看
FOC
Hi Saurav,
I am working on a custom IMX8 carrier board and I've same issue. I think it's hardware problem. How did you solve this problem?
Can you give me a some information about it?
Batuhan
3,265 次查看
saurav-pandya
GIO1_IO2 connected with watchdog, to soft reboot give low pulse to reboot in our case.
3,274 次查看
FOC
Hi Saurav,
We're working on custom imx8 carrier board and we've same error. I think it's hardware issue. How did you solve this error? Can you give me a some information about it?
3,394 次查看
Junjielu
Hi Saurav,
thanks,
Jason
3,352 次查看
saurav-pandya
Hi @Junjielu ,
Thant is our hardware issue.
Saurav
