Read ADC on mx28evk
Read ADC on mx28evk
1,509 次查看
JeromeBaron
Hi everyone,
I want to do a simple read on the lradc pins on the mx28evk. I have read a lot of threads but I could not find the answer to my question or could wrap my head around what I'm missing there.
- In the kernel menuconfig, I have "Low Resolution ADC support" checked, which set CONFIG_MXS_LRADC=y.
- In the target filesystem, I have some files related to lradc:
/sys/devices/platform/mxs-lradc.0
/sys/devices/system/mxs-lradc
/sys/devices/system/mxs-lradc/mxs-lradc-1
/sys/bus/platform/devices/mxs-lradc.0
/sys/bus/platform/drivers/mxs-lradc
/sys/bus/platform/drivers/mxs-lradc/mxs-lradc.0
- I have one dev related to that: /dev/input/ts0
Now, can I, in the filesystem, read the ADCs?
If not, should I do a simple program that use ioctl of a driver? Which driver file?
Jerome
881 次查看
pt
Senior Contributor I
I have found adc test code on the following thread.
https://community.freescale.com/message/313683#313683
Pt
4 回复数
882 次查看
pt
Pt
881 次查看
JeromeBaron
Thanks everyone for your answers. I think I'll go with the register access way like suggested by Pt. I already have a section in my code where I rewrite the PINMUX registers so I'll just do the same for the ADC.
881 次查看
fabio_estevam
On a 3.17 kernel you can read the ADC by doing:
root@freescale /$ cat /sys/bus/iio/devices/iio:device0/in_voltage0_raw
4095
881 次查看
alejandrolozan1
There is no driver of ADC in user space. But you can use as reference the touchscreen driver  source code to develop your own ADC driver in user space.
If you want to check the touchscreen funcionality in user space you can type:
cat /dev/input/touchscreen0
It seems that there is  customer's example at
LRADC with IMX28
Alejandro
