Question: best practice to read out USBx_VBUS state inYocto
330件の閲覧回数
Ralf_Rademacher
i'm interested in writing an application, (maybe an device driver) to detect when USB Connection to a charger, host PC or any other power delivering source ist established, without polling.
So whats the best way to do this? I thought about read out state of USBx_VBUS somehow or bridge this signal to an GPIO and read its state.
Is something like this possible, or are there any other recommendations.
Ralf
2 返答(返信)
284件の閲覧回数
Ralf_Rademacher
Hello Chavira,
thx for fast response. Which part in the RefManual would you advise to me, to solve my task?
I saw 4.9.11 USB Charger Detection. Is it using the VBUS-detection? How i have to enable this, because i can't find it in our Yocto.
/sys/class/power_supply is empty right now
all of the ones listed below are activated
1. CONFIG_USB-Build Support for Host-side USB
2. CONFIG_USB_EHCI_HCD EHCI HCD (USB 2.0) support
3. CONFIG_USB_CHIPIDEA- ChipIdea high-speed Dual Role Controller
4. CONFIG_USB_CHIPIDEA_UDC - ChipIdea device controller
5. CONFIG_USB_CHIPIDEA_HOST - ChipIdea host controller
6. CONFIG_USB_GADGET - USB Gadget Support
7. CONFIG_USB_MXS_PHY - Freescale MXS USB PHY support
i'm a little bit confused
Ralf
307件の閲覧回数
Chavira
Hi @Ralf_Rademacher!
Thank you for contacting NXP Support!
You can check our Linux reference manual, in that document you can see all our USB driver possibilities.
https://www.nxp.com/docs/en/reference-manual/IMX_REFERENCE_MANUAL.pdf
Best Regards!
Chavira
