Hello
I have three questions about bt.656 progressive video capture function.
In this time, section "2.5.2 CCIR Register Setting for Progressive Signal" in document
iMX6 IPU TVIN Application Notes say that
"in register IPU_CSI_CCIR_CODE_1, only CSI_STRT_FLD0_BLNK_1ST, CSI_STRT_FLD0_ACTV and
CSI_END_FLD0_ACTV are used, the three bits register value for each region (MSB to LSB) is H, V, F
data, and F is always 0."
1) Why only this three bit field are used?
2) Some video decoder output BT656 progressive data with F bit = 1.
In this time, is this decoder not used with iMX6?
3) How detect a start line of the new frame/ blanking and Active Video area?
Only F,V,H bit pattern match with CSI_CCIR_CODE_1 register bit?
or use some other condition like IPU_CSI_SENS_FRM_SIZE and IPU_CSI_ACT_FRM_SIZE value.
Ishii.
Hi Ishii
this is defined at SOC implementation stage (at design level)
right
yes, correct
Hello Igor
Thank you for your quick response.
My guess is that
CSI_STRT_FLD0_BLNK_1ST : Use as frame start and drop line data as blanking.
CSI_STRT_FLD0_ACTV : Start capture form 1st time matching after detect CSI_STRT_FLD0_BLNK_1ST,
Capture will stop condition are matched CSI_END_FLD0_ACTV or captured more then ACT_FRM_HEIGHT line.
Please tell me your opinion.
Ishii.
Hello Ishii
please look at sect.37.4.3.4 Sensor Image Frame Relations
i.MX6DQ Reference Manual
http://cache.nxp.com/files/soft_dev_tools/doc/support_info/iMX6DQPRM.pdf
