Question about Sensor Interface Timing in i.MX6S
905件の閲覧回数
ko-hey
Senior Contributor II
Hi all
I have a question about Sensor Interface Timings.
Especially, Gated Clock Mode and Non-Gated Clock Mode.
Q1.
Is the data latched at the rising edge of the valid pixel clock ?
In  IMX6SDLIEC Rev. 7, 10/2016 , there are following description for Sensor Interface Timing in Gated Clock Mode.
"Data is latched at the rising edge of the valid pixel clocks."
However, it looks the data is latched at falling edge in the Figure 58 of  IMX6SDLIEC Rev. 7, 10/2016.
Which is correct ?
Q2.
In  IMX6SDLIEC Rev. 7, 10/2016 , there are following description for Sensor Interface Timing in Non-Gated Clock Mode.
"The timing is the same as the gated-clock mode”
However, in the Figure 38-17 and Figure 38-18 of RM, the edge is the oppsite.
Is the data latched at the rising edge of the valid pixel clock in Non-Gated Clock Mode ?
Ko-hey
ラベル(3)
760件の閲覧回数
igorpadykov
Hi Ko-hey
yes data is latched at the rising edge of pixel clock and
this is valid for Non-Gated Clock Mode too. Please note there is
IPUx_CSI0_SENS_CONF[CSI0_SENS_PIX_CLK_POL] bit which selects the
polarity of pixel clock, described in sect.38.5.151 CSI0 Sensor Configuration Register
(IPUx_CSI0_SENS_CONF)
i.MX6SDL Reference Manual
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6SDLRM.pdf
5 返答(返信)
761件の閲覧回数
igorpadykov
Hi Ko-hey
760件の閲覧回数
ko-hey
Hi Igor
Let me confirm more.
According to the Figure 64, the IPUx_CSIx_DATA is latched at falling edge of IPUx_CSIx_PIX_CLK in Gated clock mode.
However, you answered that data is latched at the rising edge of pixel clock.
So the following figure is wrong. Am I correct ?
If yes, do you have any plan to revise it ?
Ko-hey
760件の閲覧回数
ko-hey
Igor
Would you follow and answer this question ?
Ko-hey
760件の閲覧回数
igorpadykov
Hi Ko-hey
As the polarity of pixel clock can be changed with
so picture above can be consdired as correct too.
760件の閲覧回数
ko-hey
That's right.
Thank you.
Ko-hey
