Qtquick 2D Render in imx6q with framebuffer
659 次查看
rgallego
I need to use in i.mx6q QtQuick with Hw 2D acceleration (no 3D), All information that i found was about DirectFB and QtQuick 2D Render, somebody tested it in imx6?
I readed that direcfb is obsoleted, and that freescale imx6 only supports X11,FB,Wayland and XWayland,
Is is possible get Qt with 2D in Framebuffer?
I'm using 4.1.15_1.0.0
regards
标签 (3)
522 次查看
jamesbone
Hello Rodrigo,
In previous version of Linux BSP  like 3.14.28.  I tested the QT version that was available in the NXP BSP and it works perfect in a i.MX6Solo and it was using Framebuffer.  In the versions  like Linux 4.1.15.  We still have the support for QT, so even I have no tested since NXP does not support  QT,  I don´t see any difference that may change the support for QT, and as you mention you have two options the use of  Framebuffer as the Framework or  the use of QtQuick 2D Render.
Hope this clarifies.
Have a nice day
523 次查看
jamesbone
Hello Rodrigo,
Have a nice day
522 次查看
rgallego
Hi James,
Thanks for your reply, I'll try again, because framebufer with QtQuick2D Render didn't work.
regards
