Qtlib problem using yocto
1,390件の閲覧回数
GiovanniFoiani
Hi all,
I installed Qt embedded on my iMX53 QSB using Yocto.
I built a Qt application using ARM toolchain on my host machine but when I try to run the application on the board I get some "library not found" errors (i.e. libQtXml, libQtGui ...).
I checked my Qt lib folder on the board and I found that all libraries have a trailing "E" ( I think it stands for Embedded ) so my libraries are libQtXmlE, libQtGuiE etc...
Is it right? What do I have to do to make my application look for embedded libraries?
Giovanni
タグ(2)
0 返答(返信)
