QDialog in Wayland works incomplete
1,018件の閲覧回数
lishaocheng
Hi, community
I deploy Qt application to embedded Linux, imx8m plus, based on Yocto Linux 5.10.52 and Wayland desktop.
Here is an example code to show the Qdialog.
MainWindow::MainWindow(QWidget *parent)
    : QMainWindow(parent)
    , ui(new Ui::MainWindow)
    ui->setupUi(this);
    d = new QDialog(this, Qt::FramlessWindowHint | Qt::WindowStaysOnTopHint);
MainWindow::~MainWindow()
    delete ui;
void MainWindow::on_pushButton_clicked()
    d->exec();
The QDialog works perfectly on x86 host PC, but my embedded Linux works incomplete.
The QDialog default position should locate at centered on top of the parent's top-level widget.
But QDialog in Wayland shows on a random position.
How to fix it ?
5 返答(返信)
699件の閲覧回数
r_trivedi123
@lishaocheng  Hope our created plugin can help for your needs,
sisigwaylandsink - A custom gstreamer plugin to control geometry
Features and demo is provided in the video link.
rutvij.trivedi@siliconsignals.io
948件の閲覧回数
lishaocheng
I remove weston,use  qt with eglfs ,works fine。
998件の閲覧回数
Zhiming_Liu
Please try latest BSP[L5.15.52] and this issue is about QT source code.
You can find similar issue in https://bugreports.qt.io/browse/QTBUG-101555
979件の閲覧回数
lishaocheng
I have done some testing and it feels like a problem with weston , I’m evaluating two solutions:
1. Replace weston with Qtwayland compositor
2. Don't use wayland at all, but use the eglfs platform plugin.
I want to know:
Are these two solutions feasible, and what impact might they have on Qt apps?
If I don't use weston or wayland, is there any impact on the GPU features provided by iMX8MP for Qt apps? Is there any relevant information to refer to?
975件の閲覧回数
Zhiming_Liu
You can replace wetson with Qtwayland, the only impact is that you can't use g2d rendering.
