Patch file for L5.10 version
908件の閲覧回数
arunsathian
Can you please provide the patch file for L5.10 version for enabling the RPMSG .
7 返答(返信)
892件の閲覧回数
joanxie
what processor do you use?
859件の閲覧回数
arunsathian
Hi @joanxie
Iam using i.MX8QXP.
815件の閲覧回数
joanxie
I don't know what kind of RPMSG patch you need, this link is for wake up A core and M core, if you need any other patch pls share more detailed information, but this patch is for 4.14, for 5.10 bsp, you need change it according to the document, if you need other kind of usage, pls let me know it
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/iMX8QXP-Use-RPMSG-to-wake-up-M4-and-A35/...
800件の閲覧回数
arunsathian
Hi @joanxie,
Can you please share the patch file for the L5.10 version to enable the rpmsg communication between A35 core and M4 core.
782件の閲覧回数
joanxie
if you just need normal rpmsg testing, don't need any patch for it pls refer to the chapter 2.8 Remote Processor Messaging of enclosed file which gives you detailed test steps
765件の閲覧回数
arunsathian
Hi @joanxie
First i need to enable the rpmsg in A35 core,for that what should I do.Can you please guide me for that.
749件の閲覧回数
joanxie
pls refer to the document I sent to you, in linux side, you can find rpmsg test under unit test folder, the detailed command, pls refer to the document I sent to you before
