PCI-E Loopback Mode
PCI-E Loopback Mode
4,097件の閲覧回数
harrytan
I am using iMX6 Solo processor and I want to have signal sent out through PCI-E Tx lane get loopback to the Rx lane. This means that Tx and Rx lanes should have the same signal. Is this done by setting the bit 2 (Loopback_Enable) of Port Link Control Register (PCIE_PL_PLCR)? Thanks.
タグ(1)
6 返答(返信)
610件の閲覧回数
Pavan_chate
Hi harrytan,
could you please explain here the procedure how you did enable the loopback and all using code warrior? I need to check the loopback in PBL mode using code warrior.
Thanks and regards,
Pavan
660件の閲覧回数
Pavan_chate
Hi ,
I am also trying to enable the loopback of bit 2. I am using LX208A  and I need to enable it by using code warrior in PBL mode.
could you please explain the detailed procedure that how you have enabled the loopback from starting onward?
2,911件の閲覧回数
igorpadykov
Hi Harry
yes this bit is used as part of Local PIPE Loopback procedure usually used
during production test. NXP software BSPs do not use this procedure.
2,911件の閲覧回数
harrytan
Hi Igor,
Do you have any thought on this? Thanks.
Harry
2,911件の閲覧回数
igorpadykov
Hi Harry
please look at IP vendor documentation
DesignWare Dual Mode Controller IP for PCI Express
2,911件の閲覧回数
harrytan
Hi igor,
I have enabled the Loopback_Enable bit and did not get the same signal on both Tx and Rx lanes. The data is sent from a FPGA to the iMX6 processor (Tx lane of FPGA to Rx lane of processor) and I probed on Tx lane of processor using oscilloscope. I expect to get the same signal on both lanes.
I further read bit[54] (mac_phy_txdetectrx_loop PIPE receiver detect/loopback request) of DEBUG 1 (PCIE_PL_DEBUG1) register and this bit is '0'. Does this mean that the PHY did not get loopback request? Please advice, thanks.
