Output format of imx vpu decoder
ソリューションへジャンプ
2,701件の閲覧回数
girijapretha
I am using decode-example from libimxvpuapi package to decode h264 file.
I am not sure about the output format of the decoder. Is it YUV420 or YUV422?
If it is not YUV422, can we decode h264 file to produce YUV422(YUYV) output?
Thanks in advance
ラベル(4)
2,505件の閲覧回数
joanxie
1) vpu output is yuv420
2) yes, you can decode h264 in yuv422
2 返答(返信)
2,506件の閲覧回数
joanxie
2,505件の閲覧回数
shivaeruventi
Can VPU produce RGB out format instead of YUV formats?
