We are proud to announce the creation of a mailing list to easy the communication of people using Freescale’s ARM processors and micro-controllers with OpenEmbedded and/or Yocto. For now, we will be using Google Groups for this task. You can join the group at http://groups.google.com/group/meta-fsl-arm
This mailing list will be used to share work and review the patches before those are merge onto the BSP layer. The layer itself has also been moved to a new repository, still at GitHub. The new repository http://github.com/Freescale/meta-fsl-arm; people already using previous meta-freescale GitHub trees you will need to change their GIT configuration to this new location.
Please join us at the mainling list and start to watch and to fork the repository at GitHub.
Hi, Vijay
Currently it doesn't support imx53smd target board, but adding the support is not complicated,
If you can figure out what is necessary to modify to add this target board you can summit pacths at http://grpups.google.com/group/meta-fsl-arm; Some hints:
New machine file, kernel and uboot recipes update to handle new target; everything else should work;
hi Adrian,
does it support for imx53smd sabre board.???
VJ
