We use OV sensor in Freescale IMX6D for camera application.
It seems the BSP may be out of memory when we run any OpenCV camera application.
We have 1G memory and the same OpenCV application runs OK on other Android 4.2/4.3 platforms.
For Freescale BSP Android4,2/4.3, it will not say out of memory until 2~3 hours.
If we change the BSP to HAL camera API version1, everything is OK.
I am wondering if Freescale BSP camera API version2/HAP implementation has bug.
Though BSP says out of memory, the GUI operation is still OK.
Attach the whole log and test APKs.
Thank
Part of log for memory issue. (Whole log, please refer to the zip file attached).
D/CameraBridge( 3083): mStretch value: 1.0
D/JavaCameraView( 3083): Preview Frame received. Frame size: 460800
I/OCVSample::Activity( 3083): onCameraFrame callback
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::workcycleObjectDetector() --- end handling imageSeparateDetecting
I/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::workcycleObjectDetector() --- objects num==0, t_ms=150.5023
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::workcycleObjectDetector() --- next step
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::workcycleObjectDetector() --- before waiting
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::process: time from the previous call is 294.618333 ms
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::communicateWithDetectingThread: shouldCommunicateWithDetectingThread=1
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::communicateWithDetectingThread: lastBigDetectionDuration=294.090334 ms
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::communicateWithDetectingThread: shouldSendNewDataToWorkThread was 1, now it is 1, since time_from_previous_launch_in_ms=294.18, minDetectionPeriod=0
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::workcycleObjectDetector() --- after waiting
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::workcycleObjectDetector() --- start handling imageSeparateDetecting, img.size=640x480, img.data=0x0x631ef010
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::communicateWithDetectingThread: result: shouldHandleResult=1
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::process: get _rectsWhereRegions were got from resultDetect
I/OBJECT_DETECTOR( 3083): DetectionBasedTracker::process: tracked objects num==0
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::process: rectsWhereRegions.size()=0
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::process: detectedObjectsInRegions.size()=0
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::updateTrackedObjects: N1=0, N2=0
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::updateTrackedObjects: start second cycle
E/Camera2-Device( 2218): setStreamSlot: Unable to clone metadata buffer!
E/Camera2-StreamingProcessor( 2218): startStream: Camera 0: Unable to set preview request to start preview: Out of memory (-12)
E/Camera2 ( 2218): startPreviewL: Camera 0: Unable to start streaming preview: Out of memory (-12)
E/Camera2 ( 2218): setPreviewCallbackFlagL: Camera 0: Unable to refresh request in state STOPPED
E/FslCameraHAL2( 2218): handleRequest: dequeue_frame failed
I/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::workcycleObjectDetector() --- objects num==0, t_ms=135.7310
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::process: time from the previous call is 207.972667 ms
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::communicateWithDetectingThread: lastBigDetectionDuration=207.215334 ms
D/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::communicateWithDetectingThread: shouldSendNewDataToWorkThread was 1, now it is 1, since time_from_previous_launch_in_ms=207.23, minDetectionPeriod=0
I/OBJECT_DETECTOR( 3083): DetectionBasedTracker::SeparateDetectionWork::workcycleObjectDetector() --- objects num==0, t_ms=86.7770
Original Attachment has been moved to: Edge-Camera-Test-Edge1.0-Edge2.x-Android4.2-4.3.zip
Hi,Lake
we have the same problem with you,and you said that "If we change the BSP to HAL camera API version1, everything is OK".
could you tell me how to change the api version of the HAL camera,just use the android4.0 or change the camera source code?
please give me a hand,thank you very much!
Best Wishes!
We have the same issue, any ideas??? :smileysad:
