Not change u-boot environment from user-space with custom board based on iMX7DSABRESD
655件の閲覧回数
tuyenth
We are using a customized board based on iMX7DSABRESD with emmc(usdhc3) .I used imx usb loader to flash u-boot for a customized board ( i do not use MFG tool). I am using u-boot u-boot-imx version 2017.03. It worked fine. When we change u-boot environment from kernel (user-space) by fw_setenv ( building from u-boot-imx version 2017.03) after using fw_printenv , I see u-boot environment is changed, but after reboot it is NOT be changed.
in file include/configs/myboard.h I set :
/* environment organization */
#define CONFIG_ENV_SIZE            SZ_8K
#define CONFIG_ENV_OFFSET        (14 * SZ_64K)
--> I must be to set in file /etc/fw_env.config
/dev/mmcblk2            0xE0000         0x2000
We don't know why. Please give us some advice.
Thanks & Regards,
2 返答(返信)
524件の閲覧回数
art
After doing fw_setenv, you have to do saveenv somehow to keep the changes in place for the next reboot(s).
524件の閲覧回数
tuyenth
Please let me know, does this issue occur on iMX7DSABRESD board?
Thank you!
