NVCC_DRAM Operating Ranges when DDR3L
1,009 次查看
ko-hey
Senior Contributor II
Hi all,
I'm using a i.MX6SL.
Let me confirm about DDR3L operating ranges.
What is DDR3L's I/O supply operating ranges ?
There is no description about in Table 9 of datasheet.
Ko-hey
843 次查看
art
DDR3L memories are rated for the operation at 1.35V I/O voltage. Typical I/O voltage range for this type of memory is 1.29V to 1.45V with nominal value of 1.35V. i.MX6SL supports this I/O voltage range.
Artur
4 回复数
844 次查看
art
Artur
843 次查看
ko-hey
Hi Artur
Let me confirm again.
According to the IMX6SLCEC, NVCC_DRAM support 1.14 V to 1.574 V and DDR3L memory's operating range is 1.29 V to 1.45 V.
So there is no concern about using DDR3L.
Is it correct ?
Ko-hey
843 次查看
art
Yes, this is correct.
Artur
843 次查看
ko-hey
Hi Artur,
Thanks !
Ko-hey
