I'm working with a custom board based in sabrelite platform, basically it is a sabrelite with NAND support.
When I try to flash the bootloader(u-boot.bin) with kobs-ng tool, it always prompt me an error.
The kernel GPMI driver find the NAND device successfully and partitions are created correctly as shown below:
Kernel GPMI driver output:
ONFI flash detected
ONFI param page 0 valid
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xd3 (Micron MT29F8G08ADADAH4)
gpmi-nand imx6q-gpmi-nand.0: enable asynchronous EDO mode 5
3 cmdlinepart partitions found on MTD device gpmi-nand
Creating 3 MTD partitions on "gpmi-nand":
0x000000000000-0x000000100000 : "boot"
0x000000100000-0x000000500000 : "kernel"
0x000000500000-0x000040000000 : "rootfs"
GPMI NAND driver registered. (IMX)
mtd partitions:
root@freescale /$ cat /proc/mtd
dev: size erasesize name
mtd0: 00100000 00020000 "boot"
mtd1: 00400000 00020000 "kernel"
mtd2: 3fb00000 00020000 "rootfs"
kobs-ng output:
root@freescale /$ kobs-ng init -v u-boot.bin
MTD CONFIG:
chip_0_device_path = "/dev/mtd0"
chip_1_device_path = "(null)"
search_exponent = 2
data_setup_time = 80
data_hold_time = 60
address_setup_time = 25
data_sample_time = 6
row_address_size = 3
column_address_size = 2
read_command_code1 = 0
read_command_code2 = 48
boot_stream_major_version = 1
boot_stream_minor_version = 0
boot_stream_sub_version = 0
ncb_version = 3
boot_stream_1_address = 0
boot_stream_2_address = 0
u-boot.bin: verifying using key '00000000000000000000000000000000'
u-boot.bin: is a valid bootstream for key '00000000000000000000000000000000'
mtd: opening: "/dev/mtd0"
NFC geometry :
ECC Strength : 8
Page Size in Bytes : 2112
Metadata size : 10
ECC Chunk Size in byte : 512
ECC Chunk count : 4
Block Mark Byte Offset : 1999
Block Mark Bit Offset : 0
mtd: opened '/dev/mtd0' - '(null)'
mtd: bootstream too large
mtd_init failed!
Can someone give a hint on this, please?
Thanks in advance.
Hi Yixing,
I am also facing the same issue but some what different.
Mine is,
/mnt/mmcblk1p1/u-boot.bin: verifying using key '00000000000000000000000000000000'
/mnt/mmcblk1p1/u-boot.bin: is a valid bootstream for key '00000000000000000000000000000000'
mtd: device /dev/mtd0 can't ioctl MEMGETOOBSEL: -1
Unable to open mtd device(s)
But at the same time I am able to save the environment and boot the uImage from NAND.
Herewith, I attached the full log file of this issue.
