Many iMX gstreamer plugins are blacklisted, beep.mp3 is missing entirely. How do I play MP3s?
5,539件の閲覧回数
ralph__
I've got a Buildroot-based system running on my iMX Solo evaluation board.
I have Gstreamer installed along with all the iMX libs and iMX patches applied to Buildroot as per Buildroot (busybox) - [PATCH 0/14 v3] freescale: update userspace packages (branch yem/fsl-imx)
Whenever I run gstreamer to try and play back an MP3 I get this output (N.B. My GST_PLUGIN_PATH has been set up correctly):
gplay /usr/sample.mp3
(gst-plugin-scanner:216): GStreamer-CRITICAL **: gst_element_class_add_pad_template: assertion 'GST_IS_PAD_TEMPLATE (templ)' failed
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_h264dec.so': lib_H264_dec_arm11_elinux.so.2: cannot open shared object file: No such file or directory
MAX resolution 1920x1080
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_audio_pp.so': lib_peq_arm11_elinux.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_mpeg4aspdec.so': lib_MPEG4ASP_dec_arm11_elinux.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_mp3enc.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_mpeg2dec.so': lib_mpeg2_dec_arm11_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_amrdec.so': lib_nb_amr_dec_arm9_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/lib_src_ppp_arm11_elinux.so': /usr/lib/imx-mm/audio-codec/lib_src_ppp_arm11_elinux.so: undefined symbol: src_up2_prefilter_proc
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/wrap/lib_vorbisd_wrap_arm12_elinux.so': lib_oggvorbis_dec_arm11_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/wrap/lib_mp3d_wrap_arm12_elinux.so': lib_mp3_dec_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/wrap/lib_aacd_wrap_arm11_elinux.so': lib_aac_dec_arm11_elinux.so.3: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/wrap/lib_aacd_wrap_arm12_elinux.so': lib_aac_dec_arm12_elinux.so.3: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/wrap/lib_aacd_wrap_arm9_elinux.so': lib_aac_dec_arm9_elinux.so.3: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/wrap/lib_vorbisd_wrap_arm11_elinux.so': lib_oggvorbis_dec_arm11_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/wrap/lib_mp3d_wrap_arm9_elinux.so': lib_mp3_dec_arm9_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:216): GStreamer-WARNING **: Failed to load plugin '/usr/lib/imx-mm/audio-codec/wrap/lib_mp3d_wrap_arm11_elinux.so': lib_mp3_dec_arm11_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:218): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_mpeg2dec.so': lib_mpeg2_dec_arm11_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:218): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libmfw_gst_amrdec.so': lib_nb_amr_dec_arm9_elinux.so.2: cannot open shared object file: No such file or directory
playbin2 is employed!
fsl_player_init(): Successfully initialize!
fsl_player_set_media_location(): filename=/usr/sample.mp3
[Stopped  ][Vol=01][00:00:00/00:00:00][fps:0]state change failed from 2 to 4
try to play failed
FSL_PLAYER_01.00_LINUX build on Sep 29 2014 22:06:59
        [h]display the operation Help
        [p]Play
        [s]Stop
        [e]Seek
        [a]Pause when playing, play when paused
        [v]Volume
        [m]Switch to mute or not
        [>]Play next file
        [<]Play previous file
        [r]Switch to repeated mode or not
        [f]Set full screen or not
        [z]resize the width and height
        [t]Rotate
        [c]Setting play rate
        [i]Display the metadata
        [x]eXit
[Stopped  ][Vol=01][00:00:00/00:00:00][fps:0] Aborted by signal[2] Interrupt...
FSL_PLAYER_UI_MSG_EXIT
fsl_player_stop()
player_exit(): No more multimedia files, exit.
g_main_loop_thread_fun() quit!
fsl_player_deinit
When I run gst-inspect-0.10 I get:
# gst-inspect-0.10 | grep imx
beep.imx: ac3: ac3
beep.imx: 3ca: ac3
beep.imx:  beepdec: beep audio decoder
isink.imx:  mfw_isink: IPU-based video sink
tvsrc.imx:  tvsrc: v4l2 based tv src
vpu.imx:  vpudec: VPU-based video decoder
vpu.imx:  vpuenc: VPU-based video encoder
aiur.imx: webm: webm
aiur.imx:  aiurdemux: aiur universal demuxer
ipucsc.imx:  mfw_ipucsc: IPU-based video converter
v4lsrc.imx:  mfw_v4lsrc: v4l2 based camera src
v4lsink.imx:  mfw_v4lsink: v4l2 video sink
But most people seem to have beep.mp3 there too. Any idea why it isn't there?
Finally, here is my list of blacklisted plugins in case it helps anyone diagnose my problem:
# gst-inspect-0.10 -b
Blacklisted files:
  lib_g.729ab_dec_arm11_elinux.so
  lib_g.723.1_dec_arm11_elinux.so
  lib_wb_amr_dec_arm9_elinux.so
  lib_g.726_enc_arm11_elinux.so
  lib_mp3_enc_arm9_elinux.so
  lib_g.726_dec_arm11_elinux.so
  lib_g.729ab_enc_arm11_elinux.so
  lib_g.711_dec_arm11_elinux.so
  lib_bsac_dec_arm11_elinux.so
  lib_g.723.1_dec_arm9_elinux.so
  lib_sbc_enc_arm11_elinux.so
  lib_g.711_enc_arm11_elinux.so
  lib_nb_amr_enc_arm9_elinux.so
  lib_g.729ab_dec_arm9_elinux.so
  lib_g.726_enc_arm9_elinux.so
  lib_nb_amr_dec_arm11_elinux.so
  lib_g.711_dec_arm9_elinux.so
  lib_g.726_dec_arm9_elinux.so
  lib_g.729ab_enc_arm9_elinux.so
  lib_wb_amr_enc_arm9_elinux.so
  lib_g.723.1_enc_arm11_elinux.so
  lib_nb_amr_enc_arm11_elinux.so
  lib_flac_dec_arm9_elinux.so
  lib_g.723.1_enc_arm9_elinux.so
  lib_flac_dec_arm11_elinux.so
  lib_sbc_enc_arm9_elinux.so
  lib_mp3_enc_arm11_elinux.so
  lib_g.711_enc_arm9_elinux.so
  lib_gif_dec_arm11_elinux.so
  lib_jpeg_dec_arm11_elinux.so
  lib_H264_dec_arm9_elinux.so
  lib_bmp_dec_arm11_elinux.so
  lib_MPEG4ASP_dec_arm9_elinux.so
  lib_png_dec_arm11_elinux.so
  lib_jpeg_enc_arm11_elinux.so
  lib_deinterlace_arm11_elinux.so
  lib_jpeg_dec_arm9_elinux.so
Many thanks.
Ralph
ラベル(5)
タグ(3)
2,433件の閲覧回数
ralph__
I've finally got this working after a somewhat epic struggle.
Basically, the gst-fsl-plugins 3.0.11 makefile was not including the mp3decoder directory when it was being built and so.... the mp3 decoder never got built.
After this it was just a matter of getting the build dependencies right between qt and the gstreamer packages.
In the end, beepdec.mp3 was not the correct mp3 plugin to use and in fact the correct plugin to use was mfw_mp3decoder. I have no idea why other people are using this beepdec.mp3 plugin as it seems deprecated.
Finally, I had wrong paths in my beep_registry.arm12.cf file. Slightly confusing how this was required even though I wasn't using the beepdec.mp3 codec.
5 返答(返信)
2,433件の閲覧回数
gusarambula
Hello Ralph,
Besides checking the gstreamer group I would recommend checking which BSP and images are showing the complete list to compare and determine where the difference may rely. There are some considering differences between the Community BSP and the BSP Release as I mentioned but also on packages available on each image.
Let us know if you are able to compare these images with the correct plugin list!
2,433件の閲覧回数
ralph__
Okay, I'm going to install a demo image and report back. Thanks.
2,433件の閲覧回数
ralph__
I managed to get mp3s playing using an old Yocto image:
http://boundarydevices.com/yocto-kernel-3-10-17-beta/#comment-591212
which is a start.
I then went back to my own build system and through much googling realised that the Makefile for gst-fsl-plugins was missing some important paths for MP3 decode.
In gst-fsl-plugins/Makefile.am, I added MP3DEC_DIR to line 930 (below the "if PLATFORM_IS_MX6" line):
SUBDIRS = $(AUDIODIRS)  $(LIBSDIRS) $(BASEDIRS) $(VPUWRAPDIRS) $(WMA8ENC_DIR) $(MP3ENC_DIR) $(MP3DEC_DIR) \
$(H264DEC_DIR) $(MPEG2DEC_DIR) $(MPEG4DEC_DIR) $(WMV9MPDEC_DIR) $(WMV78DEC_DIR) \
$(DOWNMIX_DIR) $(AMRDEC_DIR) $(IPUDIRS) $(TOOLDIRS)
When I rebuilt and rebooted the system I now had "beepdec.mp3" listed in my plugins using gst-inspect-0.10. The output from gst-inspect-0.10 beepdec.mp3 was even identical to the output on the working Yocto image system, except the codec version number had increased from 3.0.10 (on Yocto) to 3.0.11 on my system.
# gst-inspect-0.10 beepdec.mp3
Factory Details:
  Long name:    MP3 decoder
  Class:        Codec/Decoder/Audio
  Description:  Decode MP3 compressed audio to raw data
  Author(s):    Multimedia Team <shmmmw@freescale.com>
  Rank:         secondary + 2 (130)
Plugin Details:
  Description:          universal audio codec
  Filename:             /usr/lib/gstreamer-0.10/libmfw_gst_beep.so
  Version:              3.0.11
  License:              LGPL
  Source module:        gst-fsl-plugins
  Binary package:       Freescle Gstreamer Multimedia Plugins
  Origin URL:           http://www.freescale.com
GObject
+----GstObject
       +----GstElement
             +----GstBeepdec1
Pad Templates:
  SINK template: 'sink'
    Availability: Always
    Capabilities:
      audio/mpeg
            mpegversion: 1
  SRC template: 'src'
    Capabilities:
      audio/x-raw-int
                  width: { 16, 24, 32 }
                  depth: { 16, 24, 32 }
                   rate: { 7350, 8000, 11025, 12000, 16000, 22050, 24000, 32000, 44100, 48000, 64000, 88200, 96000 }
               channels: [ 1, 8 ]
Element Flags:
  no flags set
Element Implementation:
  Has change_state() function: gst_beepdec_state_change
Element has no clocking capabilities.
Element has no indexing capabilities.
Element has no URI handling capabilities.
Pads:
  SRC: 'src'
    Implementation:
      Has custom eventfunc(): gst_pad_event_default
      Has custom queryfunc(): gst_pad_query_default
        Provides query types:
                (2):    duration (Total duration)
      Has custom iterintlinkfunc(): gst_pad_iterate_internal_links_default
      Has getcapsfunc(): gst_pad_get_fixed_caps_func
      Has acceptcapsfunc(): gst_pad_acceptcaps_default
    Pad Template: 'src'
  SINK: 'sink'
    Implementation:
      Has chainfunc(): gst_beepdec_chain
      Has custom eventfunc(): gst_beepdec_sink_event
      Has setcapsfunc(): gst_beepdec_setcaps
    Pad Template: 'sink'
Element Properties:
  name                : The name of the object
                        flags: readable, writable
                        String. Default: "beepdec10"
  resync-threshold    : set threshold for resync timestamp: -1, disable resync
                        Integer64. Range: -1 - 9223372036854775807 Default: 2000000000
  reset-when-resync   : enable/disable reset when resync
                        Boolean. Default: true
  set-layout          : enable/disable set output channel layout
Sadly, I still can't play back MP3s using gplay (or using Qt for that matter). Here is the output:
# gplay /usr/sample.mp3
try to play failed
get GST_MESSAGE_ELEMENT missing-plugin, type=(string)decoder, detail=(GstCaps)application/x-id3, name=(string)"ID3\ tag\ demuxer";
Debug: gstdecodebin2.c(3576): gst_decode_bin_expose (): /GstPlayBin2:playbin0/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20:
no suitable plugins found
Error: Your GStreamer installation is missing a plug-in.
fsl_player_stop()
FSL_PLAYER_UI_MSG_INTERNAL_ERROR: internal error message received.
fsl_player_stop()
FSL_PLAYER_01.00_LINUX build on Oct 27 2014 19:42:55
        [p]Play
        [s]Stop
        [e]Seek
        [v]Volume
        [>]Play next file
        [t]Rotate
        [x]eXit
fsl_player_deinit
2,434件の閲覧回数
ralph__
2,433件の閲覧回数
gusarambula
Thank you for posting your findings! I’m sure they will help other users on the communities!
