MIMXRT1051CVL5B
MIMXRT1051CVL5B
897件の閲覧回数
sapirbuz
How does the boot process work?
How can we program the external flash?
As I understood, we should define the boot mode as a serial downloader to program the external flash through the NXP MCU (is that the only way to program the external flash?);
then, we need to change the mode to boot from fuses/internal boot so the NXP can boot after power-on.
Is it going that way?
9 返答(返信)
871件の閲覧回数
jeremyzhou
Thanks for your reply.
1) So when we program the external flash via Jlink we can define permanently the boot mode as "boot from fuses/internal boot", and program the flash even when the boot mode is on "boot from fuses"?
-- Yes.
2) When we program via serial downloader we must have the internal boot option? (because the eFuses aren't rewritable)
-- Yes.
TIC
869件の閲覧回数
sapirbuz
Thank you!
what debuggers can we use besides the Jilnk to program the external flash through the NXP MCU?
860件の閲覧回数
jeremyzhou
1) What debuggers can we use besides the Jilnk to program the external flash through the NXP MCU?
-- MCU-Link Pro, Multilink Debug Probes, etc.
TIC
840件の閲覧回数
sapirbuz
We will use MCU-Link Debug Probe as a debugger to program the external flash and to burn fuses.
https://www.nxp.com/design/microcontrollers-developer-resources/mcu-link-debug-probe:MCU-LINK?SAMLar...
We will use it with SWD, not JTAG. Will it work fine?
Do you provide a cable from the debugger (J6 connector) to the NXP board that supports only the SWD? (we want to use on our board a connector with less pins, and smaller dimensions)
834件の閲覧回数
jeremyzhou
1) We will use it with SWD, not JTAG. Will it work fine?
-- Yes.
1) Do you provide a cable from the debugger (J6 connector) to the NXP board that supports only the SWD? (we want to use on our board a connector with less pins, and smaller dimensions)
-- Yes, just as the below figure shows.
TIC
832件の閲覧回数
sapirbuz
Thank you
I don't see the cable ends in the picture below.
Can you please send its datasheet?
826件の閲覧回数
jeremyzhou
1) Can you please send its datasheet?
-- It's just a cable, it doesn't have the datasheet.
TIC
889件の閲覧回数
jeremyzhou
1)How does the boot process work?
-- Please refer to the figure FlexSPI NOR boot flow in the RM.
2) As I understood, we should define the boot mode as a serial downloader to program the external flash through the NXP MCU (is that the only way to program the external flash?);
-- No, it's not the only way, you can use the debug tool like the Jlink to program the image to the external flash directly, without forcing the MCU to enter Serial Downloader at first.
TIC
884件の閲覧回数
sapirbuz
Thank you
