Limitation on routing length of SD card I / F in i.MX6SX
813 次查看
ko-hey
Senior Contributor II
Hi all
I have a question about routing length of SD card I/F in i.MX6SX.
The length between SD card and i.MX6SX is long in my system.
Is there limitation on routing length of SD card I / F in i.MX6SX ?
Or do you have any information for recommendation for SD card development ?
Ko-hey
637 次查看
igorpadykov
Hi Ko-hey
there are no strict limitations and recommended to use ibis modelling.
Just for reference please refer to sect.3.6.8 High speed signal routing recommendations
i.MX6 System Development User’s Guide
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
sect.5.3 Minimizing Reflections AN4215 i.MX28 Layout and Design Guidelines
http://www.nxp.com/assets/documents/data/en/application-notes/AN4215.pdf
638 次查看
igorpadykov
Hi Ko-hey
