I want LTIB to use the '-j' option in calling make when building my image.
Is there something in LTIB I can tweak (even by hand)?
tom
Solved! Go to Solution.
Try looking in the *.spec file in ltib/dist/lfs-5.1 folder. I believe make is called from that file.
TomMorrison, if your question has been answered,please select Correct Answer so that the DI will be closed.
I have not tried it yet, so I can't say for sure...:-)
