LBEE5KL1PJ
LBEE5KL1PJ
idom
I redesign the i.MX 8M Mini LPDDR4 EVK Board, and I want to use LBEE5KL1PJ.
I didn't find to much information about it.
  • datasheet
  • user guide
  • how can I purchase it.
the only info I found is this link
https://wireless.murata.com/datasheet?/RFM/data/lbee5zz1pj.pdf
I couldn't find info about QCA9377
Pls advice
Ido
romitchatterjee
Contributor V
Hello, actually, the 1PJ module is no longer supported. So it would be better if you use one of the newer modules with better support. For example, the Murata Type 1MW (https://wireless.murata.com/type-1mw.html ) would be a great option for you. 1MW also has SDIO based interface and provide 802.11ac+BT 5.0, just like 1PJ, so it will work with i.MX 8M Mini very well. Refer to the Murata Quick Start guide on details of how to bring it up: https://wireless.murata.com/datasheet?/RFM/data/murata_quick_start_guide_linux.pdf .
romitchatterjee
Contributor V
Hello Ido,
Murata 1PJ module resources (datasheet, purchase information) are available at: https://wireless.murata.com/type-1pj.html . Although the order number is different from what you mention, it does use the QCA9377 module.
Hopefully this will help.
Thanks.
idom
whats the difference between the LBEE5ZZ1PJ and LBEE5KL1PJ?
I had the P\N from imx8 eval board.
why is datasheet preliminary?
On Thu, Sep 12, 2019 at 4:22 PM romitchatterjee <admin@community.nxp.com>
gusarambula
Hello Ido,
This module is manufactured and supported by Murata, so I would recommend contacting them directly asking for the technical information available and purchase information.
My apologies for the inconvenience.
idom
Thanks for your reply
