Kernel configuration
2,260件の閲覧回数
fabio_poiatti
I'm working on IMX6ULLEVK with a BSP builded from Yocto project (branch Sumo) with
linux 4.14.78
I often see the possibility to change the kernel configuration with some definition to include
in defconfig file or other ... but it is not clear the BSP toolchain, which are the autogenerated file, where
put the kernel config .... etc.
Is there any clear document to explain this chain?
Or ... in which file I have to change the definiton to change the kernel or include some feature
non enabled?
thanks
Fabio
4 返答(返信)
1,730件の閲覧回数
gusarambula
Hello Fabio Mario Poiatti,
You can open the kernel configuration using the command:
bitbake linux-imx -c menuconfig
You may also edit the defconfig file directly, which is loaded depending on your MACHINE configuration when you bake the kernel.
There is an example of adding an append to customize the kernel on the following document, it is for a different kernel version but the procedure remains the same.
https://community.nxp.com/docs/DOC-334088
I hope this helps!
1,730件の閲覧回数
fabio_poiatti
I tried with some problem ...
My host is ubuntu 18.04 and I builded an image with fsl-image-validation-imx option.
The
command open a new tab on my terminal ending with
scripts/kconfig/lxdialog/menubox.o: In function `do_scroll':
menubox.c:(.text+0x38): undefined reference to `wrefresh'
scripts/kconfig/lxdialog/menubox.o: In function `do_print_item':
menubox.c:(.text+0x173): undefined reference to `wrefresh'
scripts/kconfig/lxdialog/menubox.o: In function `print_buttons':
menubox.c:(.text+0x2d2): undefined reference to `wrefresh'
scripts/kconfig/lxdialog/menubox.o: In function `print_arrows.constprop.0':
menubox.c:(.text+0x3d4): undefined reference to `wrefresh'
collect2: error: ld returned 1 exit status
scripts/Makefile.host:111: recipe for target 'scripts/kconfig/mconf' failed
make[3]: *** [scripts/kconfig/mconf] Error 1
/home/fabio/imx-yocto-bsp/buildx11/tmp/work-shared/imx6ull14x14evk/kernel-source/Makefile:516: recipe for target 'menuconfig' failed
make[2]: *** [menuconfig] Error 2
Makefile:146: recipe for target 'sub-make' failed
make[1]: *** [sub-make] Error 2
Makefile:24: recipe for target '__sub-make' failed
make: *** [__sub-make] Error 2
Command failed.
Press any key to continue...
I need some GUI installation to have the kernel config is working?
Thanks again
1,730件の閲覧回数
rakesh_patel
Senior Contributor I
Hi fabio.poiatti@softeco.it,
You need to install 'ncurses-dev" package.
Use below command to install the package and try again.
"sudo apt-get install libncurses5-dev"
Rakesh
1,730件の閲覧回数
fabio_poiatti
Thanks!!!! :-)
