iMX6 SABRESD
Cloned the kernel at git://git.freescale.com/imx/linux-2.6-imx.git
branch imx_4.1.15_1.0.0_ga
imx_v7_defconfig
Resulting zImage works, but does not appear to load kernel modules at boot (specifically ov5640 camera driver and its dependencies). Make menuconfig shows them driver included as a module.
I tried copying a .config file from a working yocto build (imx-4.1-krogoth) but it is over-written when I "make".
已解决! 转到解答。
Hi ciaranbannon,
Please check that in /lib/modules there is a folder with the same name that you get with command 'uname -r'. If it does not exist you may create a symbolic link in /lib/modules with the same name as the uname -r output.
Carlos
Hi ciaranbannon,
Carlos
Hi Carlos. The folder in /lib/modules had the <uname -r> of my old kernel. I just updated the name, sync and reboot and it works. I'll mark your post as correct and this information is available here too.
