Is secure debug allowed on IMX8DX, if TZ OEM key & NW OEM key are in default values (0x0)?
521件の閲覧回数
cchopra
If I know the unique chip id for my IMX8DX and the fuses for TrustZone OEM key and Normal World OEM key are not set (they are still in their default values i.e. 0x0), would the challenge/response mechanism to authenticate secure debug succeed if I send both the responses as 0x0?
cchopra
@yu@har  iMX8X
3 返答(返信)
498件の閲覧回数
JorgeCas
Hello, I hope you are doing well.
Secure debug is enabled only if the chip life cycle is OEM Closed.
Best regards.
491件の閲覧回数
cchopra
What if the OEM is closed and response secrets are set to default values (0x0),  will secure debug succeed in this case, if I know the unique chip id?
cchopra
@JorgeCas
480件の閲覧回数
JorgeCas
Yes, it should be possible. Just note that response eFuses are writable only from LC OEM Open. After switching to LC OEM Closed, these eFuses are locked out.
Best regards.
