Is address incremented when using i.MX6SDL EIM continuous BCLK?
995 次查看
satoshishimoda
Senior Contributor I
Hi community,
Our customer have a question about i.MX6SDL EIM.
They consider using EIM continuous BCLK, but didn't understand whether address is incremented when using continuous BCLK.
Would you let me know it?
Satoshi Shimoda
标签 (4)
标记 (4)
825 次查看
Yuri
  In synchronous mode, after address assertion, a burst of sequential
data can be accessed, assuming address incrementing is provided
by an external device (internally). Start address of the burst is provided
by i.MX6 master. Burst length is configured in EIM. From section 22.5.4
(Burst Mode (Synchronous) Memory Operation) of the i.MX6 S/DL RM :
“When this mode is set, the controller attempts to translate the Master burst
accesses to memory burst accesses, being limited by the memory burst length,
predefined by BL value, or memory and Master WRAP/INCR boundary crossing
non-matching. Only the first address accessed is put by the controller on the external
address bus in a memory burst sequence.”
  The continuous mode is differ from single burst in such manner that
the clock is not stopped right after burst finish.
Yuri
826 次查看
Yuri
Yuri
825 次查看
satoshishimoda
Dear Yuri,
Thank you for your reply.
According to your reply, the address signal from i.MX6 is not incremented, so external device have to increment internally by its own, right?
Satoshi Shimoda
825 次查看
Yuri
Correct.
Yuri.
