Impossible to have a display via the HDMI output of the PICO-IMX8MQ (flashed with ubuntu 20.04)
363 次查看
Hpot
I flashed my pico imx8mq with a technexion ubuntu 20.04 prebuild (https://developer.technexion.com/docs/ubuntu-2204-releasenotes#prebuilt-images-available-for-downloa...).
Once turned on, I connected to the pico terminal with this command and logged:
picocom -b 115200 -r -l /dev/ttyUSB0.
I would like to connect my screen to it via HDMI (classic 1920*1080 screen). But I have this error message (screen below). and the xrandr command does not show me any HDMI connection. Maybe it has a link with the screen resolution?
Thanks in advance,
Best regards !
341 次查看
brian14
Hi @Hpot
Thank you for contacting NXP Support.
Since you are using a board and software from Technexion I suggest you contact their support. They should give you the best support.
Have a great day!
342 次查看
brian14
Hi @Hpot
Have a great day!
