If the clean Registry function (clean Register in the host PC) of Mfg tool was removed
766件の閲覧回数
StanleyLee
[Qustion}Could you confirm if the clean Registry function (clean Register in the host PC) of Mfg tool was removed or only run in background in the last releases of this tool.
[Answer] The function has been removed.
2 返答(返信)
638件の閲覧回数
StanleyLee
Hi Abisai,
Yes, The reason is we set LUN to 0.
638件の閲覧回数
AbisaiNegrete
So, t he system of PC does not become unstable since registry does not increase. That is, the problem whose registry increases was solved. is this right?
