IMX8QM: MIPI DSI display resolutions problem with CAR and CAR2 build not in Android
2,011 次查看
vinothkumars
Senior Contributor IV
Hi All,
  • IMX8QM-MEK + Android 11 Automotive + MIPI-DSI Display Interface
  • Resolutions - 1280x720
I have issue with display resolution for following Android 11 -  CAR (mek_8q_car-userdebug) and CAR2 (mek_8q_car2-userdebug) build.
But, resolutions is proper with General Android 11 (mek_8q-userdebug). So, from this display timing parameters and frequency proper. Because it is proper with general android 11.
What could be the issue with CAR build w.r.t Display resolution ?
Vinothkumar Sekar
7 回复数
1,944 次查看
jimmychan
Please read the chapter 8.3 in Android Usr's guide about the Display configuration.
Documentation could be downloaded from here:
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-automotive-os-for-i-mx-a...
1,942 次查看
vinothkumars
Thank you @jimmychan for the reply,
I tried following but it is not working,
ro.boot.gui_resolution=720p
ro.boot.displaymode=720p
Exactly, I am getting this display resolution issue under CAR and CAR2 build. Not in General Android build.
Vinothkumar Sekar
1,920 次查看
jimmychan
Is there any error message? could you send me the log?
Jimmy
1,917 次查看
vinothkumars
Hi @jimmychan
There is no error message. I able to check the current resolution by using wm size command. As per current requirements the size is 1280x720.
But, resolution is not proper
Vinothkumar Sekar
1,897 次查看
jimmychan
Could you send me the boot up log?
1,890 次查看
vinothkumars
Hi @jimmychan ,
Basically, it is look like Car Launcher overlap issue. Please conform.
Vinothkumar Sekar
1,892 次查看
vinothkumars
Hi @jimmychan ,
PFA,
I attached the boot log.
Currently I am using MIPI Display with 1280x720p with CAR build (Android 11 Automotive)
Vinothkumar Sekar
