Block noise occurs when recording with gstreamer
hsaito
I am using imx8qm.
Use openCV's VideoWriter to call gstreamer.
Below are the options to set in gstreamer.
appsrc ! autovideoconvert !  v4l2h264enc ! h264parse !\
 splitmuxsink location="+fname+ "%d" + ext + \
 " max-size-time = 60000000000  sync=false "
When recording with this, in rare cases, a video with block noise may be generated.
What is the cause when there is an abnormality in the recording file?
joanxie
you information is too limited to find the root cause
