I am facing an issue in the display of the image, I am getting 3x3 image produced, I am using UYVY8_1X1 and the respolution is set to 1080p30fps
What may be the root cause for this
Hello santhosh2,Y8_1
Which line of gstreamer are you using for this? because UYVY8_1x1 is suppose to be non supported.
Sorry Its a typo error, It is actually UYVY8_1X16 pixel format and i am using gstreamer-1.0
