IMX8MM PMIC_ON_REQ
IMX8MM PMIC_ON_REQ
1,934 次查看
santhosh2
Is there any way to toggle the  PMIC_ON_REQ using software in IMX8MM
Santhosh
7 回复数
1,923 次查看
Yuri
@santhosh2
  The PMIC_ON_REQ signal can be controlled by the LPCR[TOP] and
LPCR[DP_EN] bits, say, when the 'poweroff' command is issued in Linux.
   For power on only ONOFF pin can be used.
Yuri.
1,918 次查看
santhosh2
Hello Yuri,
I have tried this method, But the PMIC_ON_REQ pin toggles only when the switch is pressed as mentioned in the data sheet.
Since I want to Control this PMIC_ON_REQ via software to reset the entire PMIC without using the switch, Is there any other way?
Santhosh
标记 (1)
1,908 次查看
Yuri
@santhosh2
  Also, LPCR[DP_EN]  should be set.
~Yuri.
1,899 次查看
santhosh2
hello yuri,
I tried it is not working for me, Any other things needs to be done
santhosh
1,885 次查看
Yuri
@santhosh2
   is Linux command "poweroff" working on Your board?
Yuri.
1,872 次查看
santhosh2
Power off command is available, but when poweroff command fired, the system power's off but reboot doesn't happen, Please advice any next step to try?
标记 (1)
1,863 次查看
Yuri
@santhosh2
   let me know how LPCR[TOP] , LPCR[DP_EN] are written in Your tests.
Yuri.
